Law_ong Neutral Newbie April 19, 2007 Share April 19, 2007 of coz i noe its in built in the car cost, but at least i got it then others who might not have... $500 is not much but at least use it up. if its mechanical equipment they should be under warranty and i feel we should argue for the correct unless they have specify like air-con 1yr warranty etc. if they claim as wear and tear, they must give specify reason on how it wear and tear... ↡ Advertisement Link to post Share on other sites More sharing options...
Fortress Clutched April 19, 2007 Share April 19, 2007 The point is what is and not...they cannot answer and that's is lack of transparency.... Link to post Share on other sites More sharing options...
Law_ong Neutral Newbie April 19, 2007 Share April 19, 2007 if cannot, they have to fix it as equipment failure not wear and tear. if not write in to manufacturer... Link to post Share on other sites More sharing options...
Fortress Clutched April 19, 2007 Share April 19, 2007 Agree....hence I rather do importing myself or through PI Link to post Share on other sites More sharing options...
Law_ong Neutral Newbie April 19, 2007 Share April 19, 2007 u do importing? wah....u sure got lots of cold hard cash... Link to post Share on other sites More sharing options...
Fortress Clutched April 19, 2007 Share April 19, 2007 Thanks.... Link to post Share on other sites More sharing options...
Law_ong Neutral Newbie April 19, 2007 Share April 19, 2007 got lobang must intro me leh.... Link to post Share on other sites More sharing options...
Fortress Clutched April 19, 2007 Share April 19, 2007 Noted... Link to post Share on other sites More sharing options...
Brock 1st Gear April 19, 2007 Author Share April 19, 2007 (edited) To all that have replied me, many thanks. I went back to the installer to test drive my ride. After explaining to him and test driving, he commented that the brakes were ok and very good. The sound came from elsewhere. I was a bit skeptical at first. I then asked if the sound could have come from my suspension or bushings and the reply was a probable. I then requested to have them clean up and lube my bushings (I keep getting creaking noises esp going up humps and bumps). After the cleaning and lubing, test drove it and the installer came back and said, "Got sound from brakes liao." They removed the brake pads, sandpapered it, lubed the brake pad holders and test drove again. This time problem solved. He said the (new) brake pads were uneven so he had to sandpaper it to smoothen it. My squeaky stabilizer bushings problem also solved. Many thanks to all that have responded. Edited April 19, 2007 by Brock Link to post Share on other sites More sharing options...
Yeobh 4th Gear April 19, 2007 Share April 19, 2007 It is not right for yr mech to said the pad is uneven - he probably did not clean the surface of the pad propely to remove all the preservation coating. The other cleaning/ buffing job that must be carried out is the rotor disc surface to remove grease and machinging metal filings. Link to post Share on other sites More sharing options...
Brock 1st Gear April 19, 2007 Author Share April 19, 2007 Hmmm...learnt something new. What do you mean by preservation coating? Does it really matter a lot? Also, is it an absolute must for new pads to be cleaned properly of all the preservation coating before fixing on the pads? Link to post Share on other sites More sharing options...
Yeobh 4th Gear April 19, 2007 Share April 19, 2007 I am sure what what about the chemical composition of the coating. Link to post Share on other sites More sharing options...
Brock 1st Gear April 20, 2007 Author Share April 20, 2007 Sorry...but I really don't understand your last reply. Never mind then. Thanks. Link to post Share on other sites More sharing options...
Brock 1st Gear May 13, 2007 Author Share May 13, 2007 Ok...the groaning sounds came back again, even after the pads were sandpaper-ed. This time with vibration. The installer test drove and confirmed and it said the cause is the pads and the callipers being in contact with one another. He applied this rubber damper thingy on the opposite side of the brake pad (the side facing the outer callipers, not rotors. So far, no sounds and vibrations. [inline DSC00048.JPG] Link to post Share on other sites More sharing options...
Oriki Neutral Newbie May 13, 2007 Share May 13, 2007 hi.. what's the damage? where did U installed it? thx Link to post Share on other sites More sharing options...
Brock 1st Gear May 13, 2007 Author Share May 13, 2007 PM you. Link to post Share on other sites More sharing options...
Subutai 3rd Gear August 11, 2007 Share August 11, 2007 Bro... I got a somewhat similar problem as yours... can tell me what that noise silencer is and where you got your problem solved? Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Budget 2025 - February 2025.
Understanding Anti-lock Braking System (ABS)
Tatata Sounds
Tatata Sounds
Noise from front engine area (suspension,maybe) when hit bump with left turn
Braking - "Croaking" Sound
What to do when kena Shingles??
Load noise when car speed >80km/h
Screeching sound when braking
