Help need for recommedation to get rid foul smell in car and interior cleaning!
Levin
I brought @ Fairprice Xpress 239/255 East Coast Rd they hung it behind their cashier counter, i also saw @ Fairprice Xpress AMK Ave 5 usually go they to pump petrol or U can check out NTUC Xtra AMK.
I use Meguire's brand of odour remover...cannot really rem what it's called but it got the pic of a dog on it...
that time i stepped on dog **** and the bad smell lingers in my car..
spray abit on the area..next day..smell gone liao...
can get at Aut0&@cs leh...
roughly around $11.00...
hi bros. i need help i got a foul smell in the car which has been lingering around. i want to do some interior cleaning as well? any shops for recommendation to get rid of the smell as well as to do a through cleaning of the car?! cheers!
try the 3M filtrete...choose the one with carbon filter, can helps to reduce the smell...come in one big piece, cut to size of yr cabin filter box...cheap and effective [thumbsup] can also put on top of yr existing cabin filter [nod]
Wu lah...charcoal pack got..
go Daiso $2.00 shop at IMM
u pay ten dollars can get 5 packs..put at each corner of car..then every one month..put under sun to get rid of the moisture...so called moisture lah...
i got two pcks..used to put in my car...quite useful lol
for car mate..jin sway lol
that time i buy the charcoal odour remover.. (comes with a small fan with small charcoal pack inside),used less than 5 days, spoilt. Heng i buy from homefix..then one to one exhange..but for a different model..different design leh...last me close to one year liao..
hehehe...
i using the $2 charcoal block from daiso also
i put one in the fridge, under the sink, and in the wardrobe too..
all odor is eliminated! [thumbsup][thumbsup]
i do not have any biz interest in daiso. some of their things aren't even cheap (can get better for less than $2, but the charcoal block is a wonder.
neighbourhood hardware shops selling charcoal blocks of smaller size for $5 and up..
there are a few vendors pushing their wares in these thread so beware [sly][sly]
other products i can recommend are the cairefresh aircon filter with charcoal net to filter out smells, as well as the comma air con cleaner if ur ride is a few yrs old.. [nod]
i'm driving a vios, known for its smell cause i heard many complaints already. this is how i solved it. put two hippo humidifier under each front seats. i also diy 3m filter for my aircon filter. so far no smell
You can try placing a packet of coffee powder in your car [nod] It will help remove the odour. But if you think coffee smells awful, this method won't do [:p] This method was stolen from the idea that pple put coffee powder in their shoe rack to remove odours. It works in cars as well [flowerface]
the real issue shd be the air con coil. what happens is that if u switch off ur aircon while it's cold, water condenses on the coil. it will take some time to evaporate again unless ur car is parked in the hot sun. thereafter, you will get mold and fungi on ur aircon coil and stink the aircon
i dun think this is model specific. maybe some cars have a feature to prevent this, i do not know..
one method i try to practice on cooler days is to switch off the compressor when i am reaching my destination, then turn up the blower to "warm up" the coil to reduce condensation after i park.
another thing u can try for periodic maintenance is to turn ur heater up to the max on a hot day, after driving. of course u may want to do it while the car is parked. apparently, the hot air can "disinfect" the aircon, or at least reduce some smell.. Hot air is generated by the radiator, so you can get this effect only if u have been driving for more than 10 min..
personally, i don't see the need for thirsty hippo. once u open the car door or wind down the window, humid exterior air comes in again. air conditioned air is already dry by default..
if all else fails, try the daiso charcoal block too
Bamboo charcoal has other benefits too: it absorbs unpleasant room odours and harmful substances. For Odour & Humidity Protection.
Place bamboo charcoal packs in car, shoe rack, wash room, and kitchen. The packs will help remove odour, absorb moisture, and prevent shoes and clothing from mildew formation. The packs can also absorb harmful gases and unpleasant smell. Cigarette smell in the car and static electricity will be eliminated by placing Bamboo Charcoal Freshener.
its so obvious... seems like same person wif multiple nicks.
sometimes a simple "SEARCH" button yields a mini-miracle... hee hee
mice
