Terenc3 1st Gear May 30, 2007 Share May 30, 2007 After my wheel alignment.. This is the results.. (' = Degree) Front Left Actual -1'40 Before -1'51 Spcified -1'20 Range -0'10 Front Right Actual -2'20 Before -2'15 Spcified -1'20 Range -0'10 Front Cross Camber Actual -0'41 Before -0'24 According to the mechanic.. I need to install cambering nut to balance everything out.. Is it that bad that I need one? Cuz it cost S$130 to do it.. Is the price justified? ↡ Advertisement Link to post Share on other sites More sharing options...
Terenc3 1st Gear May 30, 2007 Author Share May 30, 2007 Anybody? If really need one.. Where to get a cheaper one? Link to post Share on other sites More sharing options...
Followthelaw Neutral Newbie May 30, 2007 Share May 30, 2007 I did the wheel alignment at JB for my Proton Wira,I install a set of adjustable camber nut to both side,so in future,the mechanic only need to adjusted the nuts enough,no need those other adjustments. But these nut are special and cost ard 120rm per set.Actually u can c that the nuts are special,cuase they are adjustable,can c one. Link to post Share on other sites More sharing options...
Terenc3 1st Gear May 30, 2007 Author Share May 30, 2007 Ya.. Actually the S$130 is adjustable ones.. But I dunno its one side or a pair wor.. Link to post Share on other sites More sharing options...
Followthelaw Neutral Newbie May 30, 2007 Share May 30, 2007 Yo,very seldom pple get a side,usually in a pair.Otherwise yr car serke to one side later,result in uneven alignment.Cause one side is stronger than the other.Cause these nuts damn solid,the mechanic shown to me(shld have taken pics).After installing,next x u go bk to the shop,they would know how to do. I think it's the same thing we're talking abt?But these nuts get in S'pore quite ex ah. Link to post Share on other sites More sharing options...
Ccssgm 1st Gear May 30, 2007 Share May 30, 2007 Wat is Camber NUT ......How it Look Like ?..... Link to post Share on other sites More sharing options...
Followthelaw Neutral Newbie May 30, 2007 Share May 30, 2007 I dun know how to say lah,it's a long nut and bolts,holding yr car's arms to to wheels.That's y pple say each x u chge tyres,better to do an alignment. Normal camber nuts cannot be adjusted,the mechanic will have to loosen the whole nut or tighten it altogether. But these special nuts can be adjusted,cause the ctr part is free moving,very strong,mine pair is gold in colour. Link to post Share on other sites More sharing options...
Ccssgm 1st Gear May 30, 2007 Share May 30, 2007 Thank..... Link to post Share on other sites More sharing options...
Terenc3 1st Gear May 31, 2007 Author Share May 31, 2007 Anyway.. This is the full results.. So where to install cambering nuts? Link to post Share on other sites More sharing options...
Mit81 Clutched May 31, 2007 Share May 31, 2007 Bro, i got my alignment and camber nut install @ amk autopoint. total cost plus alignment is $ 170 Address is 10, amk autopoint #04-15 Amk industrial park 2a Contact person is kenny ong@90921015 Call to book for appointment b4 goin down. Hope it help u out there. Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 31, 2007 Share May 31, 2007 Anybody? If really need one.. Where to get a cheaper one? ==================== If u r toking about a camber bolt which is slightly "oval" that will adjust the camber by just loosening the nut & then turning the bolt, I had 1 put in as recommended by my tyre guy cos the "original" bolt was too small in diameter which might cause the camber to "run" out after some time. It only cost me about $20-$30 if I'm not wrong. But I still think it's unnecessary unless your camber always runs out of tune. But as I do trust my tyre guy, I had it installed. Link to post Share on other sites More sharing options...
Terenc3 1st Gear May 31, 2007 Author Share May 31, 2007 Okay.. Price around there.. Link to post Share on other sites More sharing options...
Terenc3 1st Gear May 31, 2007 Author Share May 31, 2007 Hmm.. What I know its that the camber nut can actually be 'tuned' or adjeusted type.. Haha.. Link to post Share on other sites More sharing options...
Pisces69 6th Gear May 31, 2007 Share May 31, 2007 I'm not sure if we r toking about the same thing but mine is a bolt which has a shaft that is oval & will adjust the camber when it is rotated. Just need to loosen the nut at the end & rotate the bolt till it's adjusted then tighten back the nut. At that time I thought it was a lot of money to pay for a stupid bolt. Link to post Share on other sites More sharing options...
Terenc3 1st Gear May 31, 2007 Author Share May 31, 2007 Hmm.. Where is your trusty tyre shop located? Link to post Share on other sites More sharing options...
Mit81 Clutched May 31, 2007 Share May 31, 2007 Bro, it's adjustable to different angles. Depending on yr style of driving. Link to post Share on other sites More sharing options...
Refeer Neutral Newbie May 31, 2007 Share May 31, 2007 Hope you guys will bear with me, i'm quite lost. I'm considering getting a set of rims which is 16mm less the offset my car can take. My mechanic think its ok, just get the wheel alignment done and use, like what you guys mentioned, a camber to compensate for it. I understand the other stresses, but is he telling the truth? Link to post Share on other sites More sharing options...
Pisces69 6th Gear June 1, 2007 Share June 1, 2007 Woodlands Indl Pk.E1. ↡ Advertisement Link to post Share on other sites More sharing options...
So you really think you are BIG...
Need Advice on Self Storage
Looking for Job in automotive sector, need advise
