Activematic?
Kelfinity
Hi, can someone advise on the correct way to use activematic for Mazda cars? To speed up with manual assistance, simply to accelerate and tap M+? To slow down, to release accelerator and tap M-?
Is that the right way? i mean release accelerator then tap M+ to speed up? [hur] U driving Mz3? Recommended? Im looking at the 2l variant.
Yup Bro, i'm driving a Mz3 but the 1.6L one [:)]
To me, Activamatic is jus like driving a 'Manual' car cos you can't possibility be stepping on the accelerator and changing your gears while driving right? [:p]
Correct procedure for gear changing while driving 'Manual' cars should be release accelerator, step the clutch, change gear liao then accelerate tio bo? [:)]
Edited by Mzrmazda3
oops.. do we have to release the accelerate when we + or - on the activematic?
i just + or - when stepping on the accelerator when I'm driving on activematic [lipsrsealed][lipsrsealed]
you do not need to release your accelerator when you're shifting up or down....and yes, i drive a mazda too....
bro dun need to release the accelerator when u upshift manually...different from our manual car which we need to clutch in...
dun need to release accelerator when u upshift; just do it. the atf will do the necessary change..
for downshift because of traffic, u just slow down and brake accordingly; the gear will auto downshift. if u wanna downshift for overtake etc, just do the downshift without releasing accelerator...the ecu is programmed to allow downshift and upshift at specific speed range. check ur car manual, its stated there... [:)][:)]
This what I do in my Mazda 6 if I want to cheong my car....put AT to M position flatten the accelerator ...then shift if the RPM hit 5k and keep flooring the accelerator, since our Mazda it's not using DSG. the gear change will came around 6-6.5k RPM only for gear 1-2-3-4, 4-5th gear can't anymore lah almost 170 kmh +, engine start lost its breath. If missed to shift the gear at 5k RPM, I released the accelerator then shift, if not I will hit the rev cut on 1sr and 2nd gear (around 7k RPM rev cut kick in). I am not doing it so often, only at NSH never in SG.
Edited by Knighthunter
