Aucsl Neutral Newbie July 17, 2007 Share July 17, 2007 (edited) Anyone know where can I find this? pro and con using this? Edited July 17, 2007 by Aucsl ↡ Advertisement Link to post Share on other sites More sharing options...
Hazpower Neutral Newbie July 17, 2007 Share July 17, 2007 any shell petrol station marts should have ard 14 bucks liao..anyways its supposed to make the flat tyre tahan for a certain distance say 30km? for u to reach nearest tyre shop to change new wheels, if u dont want to change the spare tyre.. Link to post Share on other sites More sharing options...
Aucsl Neutral Newbie July 17, 2007 Author Share July 17, 2007 (edited) Thks! So for short distance only ha Thinking to use it at NSH Can the flat type be repair after using it? or must change to new one. Edited July 17, 2007 by Aucsl Link to post Share on other sites More sharing options...
Liping24 Neutral Newbie July 17, 2007 Share July 17, 2007 I think the con is that one has to take out the tyre and wash away the chemicals after the old tyre is repaired. Keeping the chemical inside the tyre will cause corrosion and unbalanced tyre right?? I think the best is to get run-flat tyres like those in the BMW3. No need for any spare tyre or repair kit. Link to post Share on other sites More sharing options...
Barachomp Neutral Newbie July 17, 2007 Share July 17, 2007 i think it would be a better idea to stick to ur spare tyre.. cos even u manage to patch it.. still no air inside.. how to drive.. if u must have a patch kit.. suggest that u buy those that looks like a worm wan.. brown colour sticky worm shape.. that 1 very lasting.. i patch my van tyre about 7-8mths ago.. still going strong now.. Link to post Share on other sites More sharing options...
Bearbear1494 Clutched July 17, 2007 Share July 17, 2007 Yup, that kind of patching kit works very well. But you'd need a couple of tools to do it properly. Obviously you would need to remove the wheel & identify where the leak is first, then if it's some foreign object embedded inside, you'd need a pair of pliers to pry it out. The tool included with the patch kit is used to insert the "worm-like thingy". Once done, you'd need to have an air pump to bring the tyre back up to the correct pressure. All said, that means that this kind of kit is more troublesome to use, so if the TS intends to use it on the NSHW, he'd have to bring along the air pump & stuff. Whereas the aerosol can kit is just "plug & play". Don't even have to remove the wheel. More of a convenience versus lasting usage kind of thing. Link to post Share on other sites More sharing options...
Picanto 3rd Gear July 18, 2007 Share July 18, 2007 this type of can thing cannot mend "injuries" to the tyre sidewall. ↡ Advertisement Link to post Share on other sites More sharing options...
Home repair advice needed
Any recommended tyre shop
Car repair and maintenance
