Jayms Neutral Newbie July 28, 2007 Share July 28, 2007 (edited) Hi guys, My car (Fiat Grande Punto) skidded when negotiating a bend on a rainy day. My left front rim hit the curb at the face with big impact casuing it to be slightly out of shape (wobble when rotating). I had the rim replaced. The steering rod was bent and I got a mechanic to straigten it back. However when I drive above 70Km/h, I could feel vibration coming from the front and could hear wierd low vibrating noise. Anyone knows what is wrong with my car? I am suspecting bent axle or damaged ball joint. Need some help to recommend a good workshop for inspection and repair. Roughly how much will such repair cost? Thanks! Edited July 28, 2007 by Jayms ↡ Advertisement Link to post Share on other sites More sharing options...
Nkotb 1st Gear July 28, 2007 Share July 28, 2007 maybe u can try posting it here : http://z13.invisionfree.com/Club_Fiatitude/index.php?act=idx Link to post Share on other sites More sharing options...
Fabulous Neutral Newbie July 28, 2007 Share July 28, 2007 Bro.. When your problem is solve... please... please go and change to a set of good tyres, this time only hit kerb, next time maybe not so lucky liao.. cheers. Link to post Share on other sites More sharing options...
Mach Clutched July 28, 2007 Share July 28, 2007 Check also gearbox mounting, driveshaft or touch wood, the gearbox itself. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear July 28, 2007 Share July 28, 2007 Simple things first. Bring your car to a good wheel alignment or suspension place and get them to check the alignement. Its more than likely a control arm may be bent but still not visible to the naked eye. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear July 28, 2007 Share July 28, 2007 I just realised you mentioned that you got the rod bent back. Even if its perfectly straight did you get a steering and wheel alignment done after??? You definately need to bring it to a wheel alignment or suspension place and get them to look at it. Link to post Share on other sites More sharing options...
Nolicense Turbocharged July 28, 2007 Share July 28, 2007 Bro, check the bearing. Link to post Share on other sites More sharing options...
Amgm125 2nd Gear July 28, 2007 Share July 28, 2007 I've experienced the same situation with you bro, skidded and my rim hit the curb. Rim is slightly deformed and the whole left wheel shifted backwards. Now car still awaiting repair and heard from the mech that besides bending back the rod/left wheel joint etc, also gotta check steering,alignment,suspension and under carriage too. Sian 1/2 Link to post Share on other sites More sharing options...
Sony 1st Gear July 28, 2007 Share July 28, 2007 Start with wheel alignment, it's cheaper.. then proceed with the rest of the checks.. and pray tell, what tyres are you on and at what speed? Link to post Share on other sites More sharing options...
Jayms Neutral Newbie July 28, 2007 Author Share July 28, 2007 Where can I find a good wheel alignment and suspension workshop? Any recommendation? I am on T1R and cornering at 70km/h. The bend is quite sharp though. Link to post Share on other sites More sharing options...
Caravan 5th Gear July 29, 2007 Share July 29, 2007 Why no one ask him to slow down next time? Must corner so fast meh? Link to post Share on other sites More sharing options...
Zizou 2nd Gear July 29, 2007 Share July 29, 2007 hullo. GP owner here too. if looking for non-geography-specific technical advise, there's another fiat forum http://www.fiatforum.com/forum good luck Link to post Share on other sites More sharing options...
macrosszero Turbocharged July 29, 2007 Share July 29, 2007 So were you attacking the corners at 99 bends? Can't be Upper Thomson as the road there has no curb, only trees and metal pillars. Link to post Share on other sites More sharing options...
Vit4wd 1st Gear July 29, 2007 Share July 29, 2007 (edited) Bro.. When your problem is solve... please... please go and change to a set of good tyres, this time only hit kerb, next time maybe not so lucky liao.. cheers. Sometimes, it's not entire the tyres' fault. It could be the speed too (cornering at 70km/h and the bend was quite sharp too, as thread starter implied). When I was using the Yokohama Aspec A300, many claimed that this tyre is unsuitable for wet roads, but it served me well and I did not experience any skids even though I have driven on tricky bends & highway speeds many at times during wet weather. Edited July 29, 2007 by Vit4wd Link to post Share on other sites More sharing options...
Sgnick 1st Gear July 29, 2007 Share July 29, 2007 Due to the accident, now u have sound can be many possible reasons, can even be the wheel bearing pit-cha due to collision. Link to post Share on other sites More sharing options...
Bennking Neutral Newbie July 29, 2007 Share July 29, 2007 Bro.. When your problem is solve... please... please go and change to a set of good tyres, this time only hit kerb, next time maybe not so lucky liao.. cheers. Bro, I couldn't agree with you more.. i plead all fellow MCF-ers to invest money on really important stuffs that will enhance handling and safety instead of spending $$ on decals or bodykits etc.. it's important! Link to post Share on other sites More sharing options...
Seaweed 1st Gear July 29, 2007 Share July 29, 2007 not to add salt...but please drive with care...good you hit the kerb and not a fellow mankind... Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear July 29, 2007 Share July 29, 2007 Where can I find a good wheel alignment and suspension workshop? Any recommendation? I am on T1R and cornering at 70km/h. The bend is quite sharp though. They're not the cheapest but South East Tyres IMHO are one of the better ones. There's one at Marine Parade and another at Ubi. ↡ Advertisement Link to post Share on other sites More sharing options...
Steering leather wrapping
Porsche’s First Steer-By-Wire System Is Designed For Less Feedback, Not More
Steering column
Steering column
the newest Mercedes model slk plaid
Reinventing the Wheel - Tesla Edition
Steering wheel off centered from seat.
Hyn Avante - Steering Got "Clock" Clock" Sound
