Fcw75 Hypersonic August 17, 2007 Share August 17, 2007 Hi, anyone knows what I can use to get rid of those sticky residue left by double sided tape on the dashboard plastic panel without affecting the paint or scratching it? Thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
RadX Moderator August 17, 2007 Share August 17, 2007 There is such a thing as tape adhesive remover, about $7 a bottle Link to post Share on other sites More sharing options...
Fcw75 Hypersonic August 17, 2007 Author Share August 17, 2007 Is it? Cool. Is it at hardware shop or car accessories shop? Would you remember where u seen it b4? Link to post Share on other sites More sharing options...
Apollo 1st Gear August 17, 2007 Share August 17, 2007 remember it is plastic.. dun use solvent or it will discolor ur plastic. want slow slow method is buy 2" wide masking tape, strip out the front to 1ft long, tape over, press down and peel off like hair remover style, then further unroll and use new ones. slow but confirmed steady one. Link to post Share on other sites More sharing options...
RadX Moderator August 17, 2007 Share August 17, 2007 Boon Lay stationery Link to post Share on other sites More sharing options...
RadX Moderator August 17, 2007 Share August 17, 2007 agree...toylet method is best Link to post Share on other sites More sharing options...
Chickenfarm Turbocharged August 17, 2007 Share August 17, 2007 Brazilian wax Link to post Share on other sites More sharing options...
Passion 5th Gear August 17, 2007 Share August 17, 2007 Hey brother,my side mirror came off,i mean those stick on one.can the solvent use to remove the residue left behind also? Link to post Share on other sites More sharing options...
Terenc3 1st Gear August 17, 2007 Share August 17, 2007 I always use alcohol for such purpose.. Fast and easy.. But whether will discolour or not.. Aiya, dun care la.. Hahaha.. Link to post Share on other sites More sharing options...
Watwheels Supersonic August 17, 2007 Share August 17, 2007 (edited) Spray some sah boon chui on it and let it soak for a while. Wipe it off with a wet cloth. Repeat the steps several times to get rid of it all. I got the idea when I observe ppl doing window tinting. Why spray mama lemon on the tinted windows to remove the tinted film?? Use mama lemon(dish washing detergent+water) lah dun cost much compared to what other ppl suggested here. Edited August 17, 2007 by Watwheels Link to post Share on other sites More sharing options...
Memory Neutral Newbie August 17, 2007 Share August 17, 2007 can pui pui some saliva n rubba rubba? lagi cheap. Tinted film on windows doesn't use any gluem but thanks for the tips because i was quoted additional $300 for removing those. Link to post Share on other sites More sharing options...
Apollo 1st Gear August 17, 2007 Share August 17, 2007 can use papa lemon instead? mama lemon will strip car wax leh Link to post Share on other sites More sharing options...
Watwheels Supersonic August 17, 2007 Share August 17, 2007 Saliva cannot lah. I use the same method to remove adhesive stains too. Work very well, I even bought tinted film to do my room's window. Link to post Share on other sites More sharing options...
Watwheels Supersonic August 17, 2007 Share August 17, 2007 (edited) Use your fav car shampoo add some water lor. Any soapy water will do. Edited August 17, 2007 by Watwheels Link to post Share on other sites More sharing options...
Mormort Neutral Newbie August 17, 2007 Share August 17, 2007 just go hardware shop find , they have it . Link to post Share on other sites More sharing options...
Dynaway 1st Gear August 17, 2007 Share August 17, 2007 Hi, anyone knows what I can use to get rid of those sticky residue left by double sided tape on the dashboard plastic panel without affecting the paint or scratching it? Thanks! take ur wife nail polish remover solution + some cotton wool to clean it off.... Link to post Share on other sites More sharing options...
Chemz Clutched August 17, 2007 Share August 17, 2007 lighter fluid, use the standard zippo one lor Link to post Share on other sites More sharing options...
Sickscientist Clutched August 18, 2007 Share August 18, 2007 I used WD40 to remove the tape residue from my gauges stand.... ↡ Advertisement Link to post Share on other sites More sharing options...
How to remove stubborn stain on windscreen?
Remove Bad Smell In The Car
Renal failure on the rise
Spare tire. do u remove or leave in boot?
Double sided tape for door visor
Veteran HK actor Liu Kai Chi 廖啟智 dies of stomach cancer at 66
