Followthelaw Neutral Newbie August 23, 2007 Share August 23, 2007 Yo all MCFers, Gg to do a major service,at 82,000km.I intend to do the below,kindly add if I had miss out anything. Engine Flush Chge Engine Oil/Filter Chge Timing Belt(Whole Set including Water Pump/Tensioner/Bearing) Chge Fan/Steering/Air-Con Belt Chge Fuel Filter Chge Clutch Fluid Chk Engine Gasket Chk Steering Bushing,if need,chge Chk Suspension Bushing,if need,chge Tyres Rotation & Alignment Also gotta chk for a screeching sound at the rear ↡ Advertisement Link to post Share on other sites More sharing options...
Apollo 1st Gear August 24, 2007 Share August 24, 2007 timin' belt depends if it is scheduled at 80km or 100km engine flush not necce must do at AD workshop suspension bushing? not sure.. most likely is the bearing gibe way but only wear then change. tyre rotation is every 10k km alignment no needed unless u hit kerb or accident. screeching sound cound b brake dust. Link to post Share on other sites More sharing options...
Followthelaw Neutral Newbie August 24, 2007 Author Share August 24, 2007 Abt the screehing sound,there wasn't any until I chged both the rear brake shoes(drum),then got the sound. Dun know is it due to the brake shoes leh. On the engine flush,is it must do at AD.Actually is a simple process what!! Link to post Share on other sites More sharing options...
Fabulous Neutral Newbie August 24, 2007 Share August 24, 2007 Bro... I did mine here...http://www.riverviewauto.com.sg/ServMajor.htm You can use their checklist as a reference... no harm... Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged August 24, 2007 Share August 24, 2007 (edited) Yo all MCFers, Gg to do a major service,at 82,000km.I intend to do the below,kindly add if I had miss out anything. Engine Flush - i dun think it is necessary.. 82000km engine only, why need to flush if its not giving u problem? my belief on engine flushing: if it aint broken, dun fix it Chge Engine Oil/Filter Chge Timing Belt(Whole Set including Water Pump/Tensioner/Bearing) Chge Fan/Steering/Air-Con Belt Chge Fuel Filter if you wanna change this, better go in workshop when fuel tank almost empty.. easier for mechanic. Chge Clutch Fluid Chk Engine Gasket Chk Steering Bushing,if need,chge Chk Suspension Bushing,if need,chge Tyres Rotation & Alignment Also gotta chk for a screeching sound at the rear [/color] brake system not included? change sparkplug? Edited August 24, 2007 by Chucky2007 ↡ Advertisement Link to post Share on other sites More sharing options...
The ownself service car hobbyist! Pls come in Share your lobangs/parts hoot
National Service in Singapore
Bad service from Top93, ubi
How to feedback on hospital service?
House painting
House painting
Maintenance Tips For Beginners/First Time Car Owners
