Rickster 5th Gear August 24, 2007 Share August 24, 2007 Ever had this before. Car's steering will vibrate at speeds above 100km/hr after changing to a new set of tyres. Sent it back tot he tyre shop for balancing again and the problem is solved . ↡ Advertisement Link to post Share on other sites More sharing options...
Victorco 2nd Gear August 24, 2007 Share August 24, 2007 do a high speed balancing will do. cost abt 20bucks or so. Link to post Share on other sites More sharing options...
Qooo Neutral Newbie August 24, 2007 Share August 24, 2007 High speed balancing also available at Stamford Tyres. Like another brother said, could be defective rims. Link to post Share on other sites More sharing options...
Weichien Clutched August 24, 2007 Author Share August 24, 2007 thanks bro. will go back there and make some noise. actually though of changing to a hard suspension, heng nv. if change cannot go beyond 90 Link to post Share on other sites More sharing options...
Hamburger Hypersonic August 24, 2007 Share August 24, 2007 most likely is the rim.tats e problem w after market rims.it seems tat they r not tat well balance,n once u swapped back 2 original 1,everyting ok liao.Shld check e centre hub too,if there is one in the 1st pl.btw,wat tyre u running on.inferior tyre will deform n a lump will appear on e surface of thread face Link to post Share on other sites More sharing options...
Rickster 5th Gear August 24, 2007 Share August 24, 2007 (edited) That happened to my family's car running on 16" original factory fitted rims with Continental sports contact. Last month just changed it to Bridgestone GR-80 and got this problem. So sent it back to rebalance and the problem is solved. Edited August 24, 2007 by Rickster Link to post Share on other sites More sharing options...
Geogeo Neutral Newbie August 24, 2007 Share August 24, 2007 (edited) sorry to hijack your thread,anyone know how much for wheel alignment?My car going left side recently. Perhaps you can consider Teo Hin which recommended by Chromas. I tried once on My FL Sunny. Nice guy. Call to check price & settings for your car model. [inline Align.jpg] Edited August 24, 2007 by Geogeo Link to post Share on other sites More sharing options...
Victorco 2nd Gear August 27, 2007 Share August 27, 2007 normally is the rim that is the problem. but sometimes is both the fixture. it happen to me once. did a balance then when mounted doing high speed balancing it is never accurate do 3 times still different location need extra weight. later the boss told the son to re mount again then do. viola everything went smoothly. vibration normally happen above 100km/h that why doing high speed is more likely to solve the problem. ↡ Advertisement Link to post Share on other sites More sharing options...
Boy in Sunglasses Dancing to Gentleman on Cruise Ship
Coolant level going down
Are You A Big Spender For A High End Bed Mattress?
