Forhod Clutched September 26, 2007 Share September 26, 2007 I am trying to remove part of a long scratch on the passenger and driver's doors, which seems to be caused by a sharp object. &$*%@# I used a 1000 grit commercial sand paper to wet sand the affect area, and wax it. The results seems to be acceptable for a noob. But I worry I would over sand the clear coat off that protects the body paint. How thick is usually factory clear coat on the car's body? Especially Nissan? ↡ Advertisement Link to post Share on other sites More sharing options...
Colin03 4th Gear September 26, 2007 Share September 26, 2007 You can try to touch-up with a layer of clear coat of paint. Hope its help . Link to post Share on other sites More sharing options...
Number19 Neutral Newbie September 26, 2007 Share September 26, 2007 Then you'll be getting a haze on the wet sanded area won't you? You're supposed to machine polish after wetsanding to restore the gloss Link to post Share on other sites More sharing options...
Bingo Neutral Newbie September 26, 2007 Share September 26, 2007 hope ur sand paper didnt left behind more scratches ......... Link to post Share on other sites More sharing options...
Forhod Clutched September 26, 2007 Author Share September 26, 2007 (edited) I'll look around when I go to the auto mart. Thanks! Edited September 26, 2007 by Forhod Link to post Share on other sites More sharing options...
Forhod Clutched September 26, 2007 Author Share September 26, 2007 Yup, I do get haze on the wet sanded area. But after a little waxing, the shine is some what there. Maybe not as good as the pros but it looks acceptable to me. Perhaps more waxing for longer duration will work like a machine polisher? Just need more time I guess. Link to post Share on other sites More sharing options...
Forhod Clutched September 26, 2007 Author Share September 26, 2007 Maybe there might be scratches, but I don't see them under the sun light. I just worry scratching the paint work badly, thus using the fine 1000 grit sand paper. Could have finish it with 2000 grit but will take more time. I just worry that I will over sand the clear coat. This is my first time doing such things. Link to post Share on other sites More sharing options...
Number19 Neutral Newbie September 26, 2007 Share September 26, 2007 Hi bro, Waxing for sure won't be able to remove the wetsanding haze cos it doesn't have abrasives to finish the paint to its original gloss state. Could you be confusing polishing with waxing? So far all of the wetsanding jobs I've seen/read require machine polishing to finish the job properly.. Cheers Link to post Share on other sites More sharing options...
Forhod Clutched September 27, 2007 Author Share September 27, 2007 Perhaps bro. But I only have wax in the car, so I just made use of what I had. Taking a glance, there isn't any haze. Maybe under strong sunlight, we may see it. I guess it looks ok for now. Thanks for the head up bro~ Link to post Share on other sites More sharing options...
Bingo Neutral Newbie October 3, 2007 Share October 3, 2007 i think after u use the sand paper, u need a pro. to buff it off for u if not u may have a problem in that area ( scratches ) because i think the 1000 sand paper very rough. ↡ Advertisement Link to post Share on other sites More sharing options...
SQ321 experienced severe air turbulence, 1 death
Clear your plates or kena orh gong ah
Porsche is now made in Malaysia!
How to clear kitchen choked floor piping?
[INCIDENT] SIA A380 experienced severe clear air turbulence
Heavy duty clear garbage bag
Massive Brawl at Apple Supplier's Factory
Stay clear! Capt Radx landing!
