Showtime Neutral Newbie November 3, 2007 Share November 3, 2007 Hi, as the engine 323 and 325 use the same engine, is it possible to unleash the 325's power from the 323 by altering the software? Also are the other transmission components similar, allowing for the 325's power to be utilized reliably? Thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Coolad 5th Gear November 4, 2007 Share November 4, 2007 Not possible... discuss countless time in overseas forum... its not just the ECU programming, the intake/exhaust and some other components are different. Basically the 325 engine block is the same as the 330 but having a smaller bore. 323 has a single stage intake manifold vs 3-stage on the 325/330. Theoretically can be done... but cost wise, you would be better off buying a 325 in the first place... Link to post Share on other sites More sharing options...
Showtime Neutral Newbie November 4, 2007 Author Share November 4, 2007 thanks man for the info. will look at the other sites to learn more about this. ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
Harddisk Diagnostic Test Software - Any good & free ones to recommend?
