Toycar Neutral Newbie June 3, 2003 Share June 3, 2003 Hello, Sad to found out that there is a very slight and slow leak from the joining lines of my engine block. 3 months I need to top up about 300ml of engine oil. I had my engine overhauled 2 year back due to gasket "burnt" and not sure why the engine leak problem. Can I use the engine "stop leak" product to solve this problem? TIA ↡ Advertisement Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie June 3, 2003 Share June 3, 2003 you can try, but if it does not solve the problem, then really another overhaul Link to post Share on other sites More sharing options...
Luke721 Neutral Newbie June 3, 2003 Share June 3, 2003 (edited) Hi, What car are you driving, and how old is it? Owned an 18 year old Hon / Accord ... so understand how you feel ... Edited June 3, 2003 by Luke721 Link to post Share on other sites More sharing options...
Xxer Clutched June 3, 2003 Share June 3, 2003 Hi, what car u driving? If its a civic, then its perfectly normal. If not, better go for a check-up. Link to post Share on other sites More sharing options...
Saaber Neutral Newbie June 3, 2003 Share June 3, 2003 seek advise from your workshop... Link to post Share on other sites More sharing options...
Vtim 3rd Gear June 4, 2003 Share June 4, 2003 It depends on the leak conditions, in a higher compression engine it's normal if you drive the car/engine hard daily. If the leak is not due to hard driving, than looks like the overhualed job wasn't done properly . The "stop leak" will only work on small areas & also if the "leak" is internal & not outside the engine, IMO. Link to post Share on other sites More sharing options...
Soya Supersonic June 7, 2003 Share June 7, 2003 The leak probably caused by the inferior quality gaskets used during the overhaul. STP Stop Leak helps to reduce the leak but depends on the severity. In any case, it's not a long term solution but useful if u r selling off the car. But be careful not to add more than 1 bottle as it'll thicken up the oil and may cause other problems later. Link to post Share on other sites More sharing options...
Duadua2 Neutral Newbie June 7, 2003 Share June 7, 2003 i just encounter my engine oil switch has leak that look like a boy urinate.but no major problem.i think u got a major problem.get advice from ur mechanic or other mechanic n ask advices. ↡ Advertisement Link to post Share on other sites More sharing options...
Coolant level going down
