Robo 2nd Gear April 8, 2008 Share April 8, 2008 wah!!! 3 hours engine still ok ar? that time my car's radiator explode i didnt realised. from geylang i drove to eunos only my gasket went up the lorry liao. den went for top overhaul also! to tell whether or not spc good. u muz try higher end oils. den u might spot the difference. well.. this is my opinion lahz. ↡ Advertisement Link to post Share on other sites More sharing options...
Maroon5 5th Gear April 8, 2008 Share April 8, 2008 bro...i use 20 oil now... i hope my engine will be ok... Link to post Share on other sites More sharing options...
Maroon5 5th Gear April 8, 2008 Share April 8, 2008 oil level drop? how old is your car and wat is the weight of the oil? anyw some oils are known to consume at a higher rate...so tats y need to check regularly n top up where nec... act my orig post was for giving carl*be a cos it served me well all the way to 10k.. Link to post Share on other sites More sharing options...
Jtis 4th Gear April 8, 2008 Share April 8, 2008 I remember that some trackies used to use Yacco, good oil. Supposedly proven to maintain lower peak oil temps on track compared to all the other branded engine oils out there... Link to post Share on other sites More sharing options...
Adawang 1st Gear April 8, 2008 Author Share April 8, 2008 its a good oil Link to post Share on other sites More sharing options...
Genie47 1st Gear April 8, 2008 Share April 8, 2008 If you are not racing, 5W30 goes well with any new modern engine. Link to post Share on other sites More sharing options...
Squareone Neutral Newbie April 8, 2008 Share April 8, 2008 Are all 5w30 oil the same? Have been using SHU but thinking of changeing to carl*be 5e30 oil for a change. Link to post Share on other sites More sharing options...
Dwoon 1st Gear April 8, 2008 Share April 8, 2008 What are the symptoms that the gasket has gone??? I've also just recently blown my radiator. Kept adding water to tahan till I got to the workshop. wah!!! 3 hours engine still ok ar? that time my car's radiator explode i didnt realised. from geylang i drove to eunos only my gasket went up the lorry liao. den went for top overhaul also! to tell whether or not spc good. u muz try higher end oils. den u might spot the difference. well.. this is my opinion lahz. Link to post Share on other sites More sharing options...
Tigerson Neutral Newbie April 8, 2008 Share April 8, 2008 My friend have M1 5W50 oil but date of produce is jan 2006. can I buy from him and use.What is the self life. Link to post Share on other sites More sharing options...
Maroon5 5th Gear April 8, 2008 Share April 8, 2008 bro, take one bottle from him n look for the expiry date....may b written on it... Link to post Share on other sites More sharing options...
Josephteo 1st Gear April 8, 2008 Share April 8, 2008 Hi Bro Genie... and Guru of CNG... any good 10W30 oils to recommend? Amsoil? Link to post Share on other sites More sharing options...
Genie47 1st Gear April 8, 2008 Share April 8, 2008 Synthetics are better but for a car that is hardly pushed through it's paces, it wouldn't matter what brand. Link to post Share on other sites More sharing options...
Genie47 1st Gear April 8, 2008 Share April 8, 2008 I will not recommend brand names. Link to post Share on other sites More sharing options...
Josephteo 1st Gear April 8, 2008 Share April 8, 2008 icic..no problems...sorry for asking bro... Link to post Share on other sites More sharing options...
Tigerson Neutral Newbie April 8, 2008 Share April 8, 2008 Bro,thanks.will do that. Link to post Share on other sites More sharing options...
Adawang 1st Gear April 8, 2008 Author Share April 8, 2008 I may try the following Redline Pennzoil Amsoil Motul 300V for next service Link to post Share on other sites More sharing options...
Squareone Neutral Newbie April 8, 2008 Share April 8, 2008 Thanks. Will give Carl*be 5w30 syn a shot for my next oil change later this week. Maybe will post some feedback after that. Link to post Share on other sites More sharing options...
Garlic 1st Gear April 8, 2008 Share April 8, 2008 (edited) Genie, Are you still a dino supporter? Cheap + meet specs = wack? Edited April 8, 2008 by Garlic ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
SCHNELL Engine Oil 5W40
