Engine oil
Adawang
im driving a 16 yr old coming 17 car. just change my oil in feb. b4 the change and flush i was using cxxxxxe 5W40. when hit 4k the oil very black and dirty liao. den flush that time. the car like lao sai like that. problem is before i change to cxx xxxe i also flush liao. conclusion is mechanic say this oil not good for my car.
then he tell me try OWS multilight 10W40. change liao now clock 3K+ the oil still like swee swee. slightly brown only. then FC and power much better than usual.
in my opinion the oil is bad. change it. [;)]
after try OWS i would say highly recommended. some might have other opinions. heard redline, amsoil and royal purple not bad. u might wanna try it out. im not really a supporter of commercialise products like M1, SHU and Castrol. so if asked me i wont used those.i think they over price liaoz.
Bro for a car that's coming to 17yrs old is better to use 15w40, 15w50 or 20w50. Your current 10w40 oil only clock 3K+ wait till u clock 5K+ then u check see whether swee swee or not [laugh]
I intend to use Caltex Delo Silver multigrade for next oil change to clean my 110k km engine.
Any other suggestions?
oil level drop? how old is your car and wat is the weight of the oil?
anyw some oils are known to consume at a higher rate...so tats y need to check regularly n top up where nec...
act my orig post was for giving carl*be a cos it served me well all the way to 10k..
that time was using w30 so drop like crazy. den e carl*be is black very easily.. can last till 10k no problem. but jus very dirty...
btw.. mine's a old ride. 16yrs old
What are the symptoms that the gasket has gone???
I've also just recently blown my radiator. Sweat Drop Kept adding water to tahan till I got to the workshop.
that time my radiator blew. e water pipe also up e lorry.. try pouring like 10 litres of water, on top go in below flow out, mayb is the car old liao. cannot start at all, start liao white smoke enguff the back. lol. den open the hood. i think i can make a well-done steak there. temp stuck at red for like 3hrs straight.
probably thats a sign gasket up e lorry.
called for a tow truck. den bring to my workshop. mechanic told me radiator gone, water pipe gone, gasket gone.
hmm... serious ah? i will monitor then. but wont w50 be an overkill???
if really jialat i will go ahead with your recommendation.
and paiseh for one shot reply all.. [laugh]
Edited by Robo
oic mayb too thin for your car...old car is like tat cos the gaskets are old..so its easy for the EO to sip into the chambers...my old car 14yrs old i used semi-syn 5w50....no problems... laugh.gif
im driving a 16 yr old coming 17 car. just change my oil in feb. b4 the change and flush i was using * 5W40. when hit 4k the oil very black and dirty liao. den flush that time. the car like lao sai like that. problem is before i change to * i also flush liao. conclusion is mechanic say this oil not good for my car.
Bro for a car that's coming to 17yrs old is better to use 15w40, 15w50 or 20w50. Your current 10w40 oil only clock 3K+ wait till u clock 5K+ then u check see whether swee swee or not laugh.gif
My previous car reached 16 years and clocked over 400k km still ran 10w30 without any problem. Just consumed some engine oil which I think is normal for a high mileage car...
I have noticed my engine oil turned black quickly
have driven abt 600 km from last service
car is < 2 years old
used synthetic 15W 50 for this last service, have been using 05w 40 previously
if it turns black quickly, does it mean that the oil is doing its job in cleaning the engine.
or the oil quality is not good
I don't do UOA
What is the mileage of your car that you need to use 15W-50?
Use 5W-20 or 5W-30 if car mileage is less then 100k..else it will have poor fuel economy.
I'm presently using Mobil1 extended performance which can last till above 24k...
Edited by Sonicmood
[reply]w30 will not give you more power, maybe a more smooth engine, and slightly better FC if you continue to drivafter service with 50 weight, engine feels smooth
after service with 50 wt oil, engine feels smoother than 40wt oil
here are the fc figures
1st tank, 310 km on 45.12 L =6.87 kml
2nd tank, 334.1 on 45.31 L =7.37 kml
3rd tank 342.6 on 45.76 L =7.48 kml
4th tank, 359 km on 45.45 L =7.89 kml
quite happy with the last tank. I have never achieved this kind of good figures before.
cud be attributed to light foot driving.
can see the figures getting better as it goes
The smaller the "W" nos the lighter the oil does giving better FC...
Anyway, I'm using both fully synthetic Amsoil and Mobil1 extended performance w20 and w30 range...
driving a 1.8L(A) on SPC95 petrol and getting about 580km/45L which is about 12.5km/l on a 60-HW 40-City with oil change at every 20k...
BTW, if you are using fully synthetic oil then why change oil at 5k interval? [sweatdrop]
Edited by Sonicmood
w stands for winter, not applicable here
5k is the factory recomended interval,
One can never change oil too often, hahaha
oil change at 20k, wow
will the oil be good after so many km?
Edited by Adawang
sorry for not making myself clear... [dizzy]
I mean the nos behind the "W"...heehee..
Huh...5k interval by factory??
May I know what is your ride...?
For what I know most jap ride stated a 10k interval while conti ride are at 15k...
My bro audi is doing a 15k interval...
20k interval so far got no issues... [laugh] cos the oil i used can travel 15k miles b4 the next oil change...which is about 24k... [thumbsup]
I did that for all my previous 4 rides [;)]
Edited by Sonicmood
