Tay107 Neutral Newbie April 19, 2008 Share April 19, 2008 my car alarm trigger in morning thunder only my car last time do see 1 or 2 car trigger. lucky i still can sw off at home if not have go near car and off it. but normal time i hv go near car then can trigger door open any setting in the alarm system i can set to stop this thubder alarm ↡ Advertisement Link to post Share on other sites More sharing options...
Apollo 1st Gear April 19, 2008 Share April 19, 2008 valet parking setting i guess. best is if u hv 2 way FM paging so u know when it goes off Link to post Share on other sites More sharing options...
Bluemice 2nd Gear April 19, 2008 Share April 19, 2008 is your alarm stock or OE ones ?? if its OE and due to the shock sensor that trigger it, u shld be able to do a one-time shock sensor disable. this is to prevent the vibrations from the thunder to trigger it. eg Crimestopper shock sensor is able to hv one-off shock sensor disable. mine shares the same problem when parked in an open carpark during a heavy thunder storm. mice Link to post Share on other sites More sharing options...
Tay107 Neutral Newbie April 19, 2008 Author Share April 19, 2008 just tk the manual to ck found there is remote shock sensor override press button 1 +2. but is only temporary. think when next door open will reset to normal. each time when there is thunder i hv to de-active the sensor. Link to post Share on other sites More sharing options...
Girl_powerful Neutral Newbie April 19, 2008 Share April 19, 2008 Last Night's Thunder storm cause several cars in my estate to sound their alarm, Lucky not mine. Link to post Share on other sites More sharing options...
Bluemice 2nd Gear April 19, 2008 Share April 19, 2008 if u want perm disable... just set the 1st + 2nd level activation sensitivity to the min.... this way even a dump truck hit your ride also wun get any activation. one other way is to unplug the cable from the sensor module... mice Link to post Share on other sites More sharing options...
Kieran1975 1st Gear April 19, 2008 Share April 19, 2008 my car alarm trigger in morning thunder only my car last time do see 1 or 2 car trigger. lucky i still can sw off at home if not have go near car and off it. but normal time i hv go near car then can trigger door open any setting in the alarm system i can set to stop this thubder alarm Hi bro, i have the same with my STW800 alarm. The installer change the shock sensor to another location and everything seems to be ok liao.... The other method is to disable the shock sensor..... Link to post Share on other sites More sharing options...
Tay107 Neutral Newbie April 19, 2008 Author Share April 19, 2008 that good but must know where is the sensor. more shock any problem ??? my is vector 600 alarm. Link to post Share on other sites More sharing options...
Bluemice 2nd Gear April 19, 2008 Share April 19, 2008 Get your installer to do it for you. loc of the shock sensor is impt to ensure a all round protection against impact and also correct trigger. mice Link to post Share on other sites More sharing options...
Tay107 Neutral Newbie April 20, 2008 Author Share April 20, 2008 thk u bro. will goto KM to check. mean time i just de-active the light shock sensor. Link to post Share on other sites More sharing options...
Bcyn Neutral Newbie April 20, 2008 Share April 20, 2008 where do one usually place a shock sensor to ensure all round protection den? ↡ Advertisement Link to post Share on other sites More sharing options...
Aftermarket Alarm
Aftermarket Alarm
Aftermarket car alarm
Car Alarm
Car Alarm
Car alarm issue
Car alarm issue
Alarm issue
Alarm issue
Alarm and Lock issue
Any bro using SPY 2 way Alarm
Viper Alarm - Where to get?
