Roverboy 1st Gear June 12, 2003 Share June 12, 2003 whenever i start my car in the morning, there is a weeing sound coming out from the bonnet,what i suspect is the belts, but i just change the timing belt n the rest of the belts, b4 changing those belts also got this problem, pls help!! many thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Redliner_sg Neutral Newbie June 12, 2003 Share June 12, 2003 mebbe belts, or aircon compressor. Just a hunch, dunno if accurate. Does it change pitch when you rev it up? Link to post Share on other sites More sharing options...
Roverboy 1st Gear June 12, 2003 Author Share June 12, 2003 no it doesnt,only when after crank up Link to post Share on other sites More sharing options...
Roverboy 1st Gear June 12, 2003 Author Share June 12, 2003 esp load in the morning or after a few hour after last drive Link to post Share on other sites More sharing options...
Modeldriver Neutral Newbie June 12, 2003 Share June 12, 2003 If you've just changed, suggest you go back to the repair shop and complain. There should also be a belt driving the aircon compressor ? Maybe it's that one. Link to post Share on other sites More sharing options...
Redliner_sg Neutral Newbie June 12, 2003 Share June 12, 2003 my hunch is that its your belts, Check the tension of your belts. Either that your they need lube, too dry Link to post Share on other sites More sharing options...
Roverboy 1st Gear June 12, 2003 Author Share June 12, 2003 i tink i will get a belt spray to rect it, thanks Link to post Share on other sites More sharing options...
Redliner_sg Neutral Newbie June 12, 2003 Share June 12, 2003 anytime Link to post Share on other sites More sharing options...
Soya Supersonic June 13, 2003 Share June 13, 2003 sounds like the belt tension is set incorrectly. better to go back to the mech to tighten it, wd-40 is only an interim solution. loose belts can snap. Link to post Share on other sites More sharing options...
Duadua2 Neutral Newbie June 13, 2003 Share June 13, 2003 its ur belting.tell ur mechanic dat its annoying u.or maybe its ur ECU. Link to post Share on other sites More sharing options...
Orangie Neutral Newbie June 13, 2003 Share June 13, 2003 Very likely its the belts. Had similar experience before. Whenever I start my car, the whole neigborhood can hear the squeaking sound . Sound is gone after driving for some time. Machanic say I'm using a lower quality belts. Changed the belts, ok liao Hope this help Link to post Share on other sites More sharing options...
Roverboy 1st Gear June 13, 2003 Author Share June 13, 2003 but i had change to good quality belt Link to post Share on other sites More sharing options...
Orangie Neutral Newbie June 13, 2003 Share June 13, 2003 Like that don't know liao. Could be a worn out bearing for the belt tensioner. But this squeaking sound will not stop when the engine is running. I kanna also. In the end, change 2 bearing. 1 for belt tensioner and 1 for timing belt. Hope this help ↡ Advertisement Link to post Share on other sites More sharing options...
To be Happy, start thinking about Death!
Engine Mounting
Engine Mounting
