Junjie 1st Gear May 22, 2008 Share May 22, 2008 Hi all, Oversea assignment for 1 mth.. thinking of disconnecting the battery. I understand to remove is negative terminal first follow by positive terminal and to connect back is the reverse...the question is do I need to remove both terminals or just remove the negative connection can liao.....any bro can advise, thks... ↡ Advertisement Link to post Share on other sites More sharing options...
Apollo 1st Gear May 22, 2008 Share May 22, 2008 remove negative can liaoz... but not advisable to do this. pass key to some1 just start the engine in 2 weeks later for ard 10-15 mins. reason is tat ur ECU taps fr battery. if ur ECU is reset to factory default, ur FC may go up. also for security reason, my advise is remove everything fr the car visually and place in boot. even fr the front dash, keep dash box open empty. keep cashcard cover open, no card. no parking coupons. if u hv wiper stand, keep the wipers up. steering locked. Link to post Share on other sites More sharing options...
Friendstar Supercharged May 22, 2008 Share May 22, 2008 what is wiper stand? Link to post Share on other sites More sharing options...
Junjie 1st Gear May 22, 2008 Author Share May 22, 2008 Thks bro, but starting the car and let it idle doesn't charge up the battery unless it's driven for a period....bcos OC no licence, can only sit inside and start engine to let it run...therefore I was thinking whether should I disconnect.... Link to post Share on other sites More sharing options...
Junjie 1st Gear May 22, 2008 Author Share May 22, 2008 guess it's for those that park in the open,mine is MSCP, not so bad.... Link to post Share on other sites More sharing options...
Nys75 Neutral Newbie May 22, 2008 Share May 22, 2008 Not necessary to drive. In neutral gear, increase the rpm to >2000 rpm so that the alternator could have the optimum voltage to charge the batt. However, wasting petrol. Link to post Share on other sites More sharing options...
Ericang69 Neutral Newbie May 22, 2008 Share May 22, 2008 Not advisable to disconnect -- start engine and let idle for 10 minutes weekly will do. Cheers Link to post Share on other sites More sharing options...
Junjie 1st Gear May 22, 2008 Author Share May 22, 2008 May I know why not advisable to disconnect besides resetting of ECU, all pre-set stuffs on the HU gone.....anything I miss out? disconnecting will do more harm to the car? pls advise..thks Link to post Share on other sites More sharing options...
Ericang69 Neutral Newbie May 22, 2008 Share May 22, 2008 Battery may go flat by then -- unable to start yr engine. Link to post Share on other sites More sharing options...
Kklee 6th Gear May 22, 2008 Share May 22, 2008 IMHO, preferably to disconnect the battery as the self discharge is slower. If battery is in good condition, can just leave it but remove any VS or any devices than potentially drains the battery. Crank starting a car requires battery juice. Engine idle, because of the higher voltage, could still charge the car battery but whether that tens of minutes is sufficient to replenish what is taken out by the cranking is difficult to determine. Batteries left in their discharged state for a period of time will have their lifespan shorten. Link to post Share on other sites More sharing options...
Ncss Clutched May 22, 2008 Share May 22, 2008 (edited) Hi all, Oversea assignment for 1 mth.. thinking of disconnecting the battery. I understand to remove is negative terminal first follow by positive terminal and to connect back is the reverse...the question is do I need to remove both terminals or just remove the negative connection can liao.....any bro can advise, thks... I think dont need remove battery. For modern cars, 1 month no touch the car is still alright. A few weeks no problem la, Car can still start easily... depends on your battery condition la. Probably you may let the engine run to charge the battery a while before you go oversea. Best still, ask friend or relative to help you engine run charge once a week. Like that at least someone know your car is still there . Edited May 22, 2008 by Ncss Link to post Share on other sites More sharing options...
Hiphiphoray 6th Gear May 22, 2008 Share May 22, 2008 remove negative can liaoz... but not advisable to do this. pass key to some1 just start the engine in 2 weeks later for ard 10-15 mins. reason is tat ur ECU taps fr battery. if ur ECU is reset to factory default, ur FC may go up. also for security reason, my advise is remove everything fr the car visually and place in boot. even fr the front dash, keep dash box open empty. keep cashcard cover open, no card. no parking coupons. if u hv wiper stand, keep the wipers up. steering locked. U do not want to fark up the ECU. U have to send in to AD for resetting!!!!! Link to post Share on other sites More sharing options...
Tech21 Neutral Newbie May 22, 2008 Share May 22, 2008 Sorry guys, noob here..check with you how good battery -> 13.6V - 14.2V during driving? Without turning to ignition, Battery = 12V Are these 2 conditions define as healthy battery? Many thanks guys! Link to post Share on other sites More sharing options...
Apollo 1st Gear May 22, 2008 Share May 22, 2008 Thks bro, but starting the car and let it idle doesn't charge up the battery unless it's driven for a period....bcos OC no licence, can only sit inside and start engine to let it run...therefore I was thinking whether should I disconnect.... just crank the engine let it warm up a bit.. for 10 mins is all tat is needed for the alternator to power up the battery, no nid to drive ard wat. Link to post Share on other sites More sharing options...
Apollo 1st Gear May 22, 2008 Share May 22, 2008 A car battery is a type of rechargeable battery that supplies electric energy to an automobile[1]. Usually this refers to an SLI battery (Starting - Lighting - Ignition) to power the starter motor, the lights, and the ignition system of a vehicle Link to post Share on other sites More sharing options...
Kklee 6th Gear May 22, 2008 Share May 22, 2008 IMHO, actually it's much more complicated but my take on your questions... Without turning on ignition AND when the vehicle has rested for 4-6 hours, ideal battery voltage should be 12.6V. Any voltage > 12V could mean battery not fully charged or the battery is damaged. However, the voltage alone does not determine whether the battery has enough charge to crank start the car. A more accurate way is to use a load or CCA tester. 13.6v - 14.2v during driving in most cases means the alternator is working correctly. Link to post Share on other sites More sharing options...
Tech21 Neutral Newbie May 22, 2008 Share May 22, 2008 Thanks brother for the information! Link to post Share on other sites More sharing options...
Tech21 Neutral Newbie May 22, 2008 Share May 22, 2008 Thanks for your reply ya, I think its time for me to check and if possible change the battery..its been 1.5 years anyway. ↡ Advertisement Link to post Share on other sites More sharing options...
My EV journey to the i4
Battery for Honda Vezel
