Up genting using garmin gps
Jian
Anyone here uses their garmin gps to genting? What is the address to key in?
Hi there... I just return from Genting Highlands last weekend and was using my garmin to guide us there... from here, you can go to SPELL function and key in Genting Highland, or First World... make sure you are able to receive coverage for your garmin to calculate your distance and estimated time of arrival... from there, just follow until KL exit where you need to rely partly on your garmin and the signboards as at times you need to filter out earlier than your garmin prompt you to... for me, the basic rule to follow after KL is look at the signboard for 'Cheras', then 'Kuantan' and finally you can see 'Genting Highlands'... your garmin will also the same route but may not necessary reflect the names mentioned... hope this helps bro... drive safely... [;)]
