Hobbiez Neutral Newbie June 27, 2008 Share June 27, 2008 Hi Everyone, Need some help to find the unknown angles BAD and CED. Given angle BCD = 132. Angle A is at centre of circle. Thanks for all input. ↡ Advertisement Link to post Share on other sites More sharing options...
Chisiang 2nd Gear June 27, 2008 Share June 27, 2008 how about C? Center also? Link to post Share on other sites More sharing options...
Chisiang 2nd Gear June 27, 2008 Share June 27, 2008 is BCE a straight line? Link to post Share on other sites More sharing options...
Hobbiez Neutral Newbie June 27, 2008 Author Share June 27, 2008 (edited) Yes angle C is also centre and BCE is straight line. Thanks for pointing that out. Edited June 27, 2008 by Hobbiez Link to post Share on other sites More sharing options...
David Clutched June 27, 2008 Share June 27, 2008 I think BAD = BCD = 132 Link to post Share on other sites More sharing options...
Chisiang 2nd Gear June 27, 2008 Share June 27, 2008 CED is 66 deg irregardless of the radius of the circle Link to post Share on other sites More sharing options...
Porker Turbocharged June 27, 2008 Share June 27, 2008 Angle CED = 66 degrees Angle BAD = 132 degrees Link to post Share on other sites More sharing options...
Hobbiez Neutral Newbie June 27, 2008 Author Share June 27, 2008 Thanks for your input. Yes I agree with you since BCE is stragiht line, we can find CED. Link to post Share on other sites More sharing options...
Hobbiez Neutral Newbie June 27, 2008 Author Share June 27, 2008 Thanks David. May I know why BAD is equivalent to BCD? Link to post Share on other sites More sharing options...
Hobbiez Neutral Newbie June 27, 2008 Author Share June 27, 2008 Thanks Porker. How come you change avatar again? What is reason BAD is same as BCD? Link to post Share on other sites More sharing options...
Porker Turbocharged June 27, 2008 Share June 27, 2008 Work with the following facts: 1) CED is isoceles 2) BCD is isoceles 3) BAD is isoceles 4) AD and BCE are parallel Link to post Share on other sites More sharing options...
Skylander Neutral Newbie June 27, 2008 Share June 27, 2008 I dont know correct or not but here goes. Looks like Sec school question. C = centre of circle, thus CD = CE = radius of circle therefore triangle CDE is isosceles and angle CDE = angle CED. Using theory of ext angle of triangle = sum of 2 int angle of triangle, angle CED = 132/2 = 66 deg (since both angles CDE and CED are the same) For angle BAD, using opposite angle in cyclic quad (is this possible?) Angle BAD = 180 - 66 = 114 deg Correct me if i am wrong Link to post Share on other sites More sharing options...
Chisiang 2nd Gear June 27, 2008 Share June 27, 2008 AD and BCE parallel meh? neber say Link to post Share on other sites More sharing options...
Hobbiez Neutral Newbie June 27, 2008 Author Share June 27, 2008 Thanks Skylander. If I'm correct, cyclic Quad is when the four corners touch the same circle. Link to post Share on other sites More sharing options...
Porker Turbocharged June 27, 2008 Share June 27, 2008 Some things no need to say can infer also. The examiners where got so nice give you everything? Link to post Share on other sites More sharing options...
Hobbiez Neutral Newbie June 27, 2008 Author Share June 27, 2008 The question did not mention on this too. I apologised Chisiang. Link to post Share on other sites More sharing options...
Skylander Neutral Newbie June 27, 2008 Share June 27, 2008 oh yah hor.... suddenly remember, thanks for pointing out. But at points ABDE, consider touch the same circle? Or must not pass through centre of circle? Link to post Share on other sites More sharing options...
Hobbiez Neutral Newbie June 27, 2008 Author Share June 27, 2008 Hey you are good! Yes ABDE is a cyclic Quad. ↡ Advertisement Link to post Share on other sites More sharing options...
MOM help FTs look for jobs ?
RAM/MicroSD issues
RAM/MicroSD issues
