Darkblue 1st Gear July 14, 2008 Share July 14, 2008 Hi bros, Have been having this steering wheel problem since few months ago, decided to fix it since its getting kinda irritating. Problem is when cruising straight on the expressway, the steering wheel position is at 11 o'clock. I do not have any bosskit installed, my steering wheel is stock. It happened after I done my alignment. I don't think its tram-lining because the tyres is new when I done my alignment. I called one workshop to enquire, mech told me to let go the straight wheel see if the car will veer to the left/right. Car tracks perfectly straight... Can I conclude that alignment is ok, problem is the steering wheel position ? If yes, where can I go to adjust my steering wheel without altering the alignment ? Thanks alot for your time Cheers ! ↡ Advertisement Link to post Share on other sites More sharing options...
Fitvip Supersonic July 14, 2008 Share July 14, 2008 (edited) It is because the alignment was done when the steering wheel was at 11 o'clock! ( I experienced it before) Go and do the alignment again with the steering wheel locked at 12 o'clock! Edited July 14, 2008 by Fitvip Link to post Share on other sites More sharing options...
Kawarides Neutral Newbie July 15, 2008 Share July 15, 2008 Bro go and have your steering wheel centralised by adjusting the p/s tie rod. You will need to adjust the LHS tie rod shorter by 15 mins of the clock and lengthen the RHS tie rod by 15 mins. If you dun understand what I mean just inform your mech I think they will understand. Link to post Share on other sites More sharing options...
Enzomatrix 2nd Gear July 15, 2008 Share July 15, 2008 had that problem b4, went back to AD, come back properly done Link to post Share on other sites More sharing options...
Darkblue 1st Gear July 15, 2008 Author Share July 15, 2008 Thanks all bros for feedback Bro Kawarides, any idea why in the 1st place the workshop change the tie rod during alignment (from normal -> 11 o'clock) ? is it the workshop lazy just do alignment then collect $$ ? Link to post Share on other sites More sharing options...
Kawarides Neutral Newbie July 15, 2008 Share July 15, 2008 Bro sometimes after wheel aligment the steering will not be in center position. 1) Ask your workshop to centerised your steering wheel 2) Request them to perform a side slip test or even a wheel alignment test again to further confirm your alighment is not affected by the adjustment. 3) Finally confirmed by going for a roadtest. As your question I have no answer, all depends on your workshop quality control Most likely is carelessness. This is an easy task,surely your workshop can do it. The P/S tie rod is use to adjust and centralised your steering wheel , additional adjustment is for your Toe-In & Toe-Out for your wheels in order to pass the yearly Inspection.This part is not replace unless you had an accident. Hope that might clear your doubt Link to post Share on other sites More sharing options...
Darkblue 1st Gear July 15, 2008 Author Share July 15, 2008 Thank you bro Cheers !! Link to post Share on other sites More sharing options...
Apollo 1st Gear July 15, 2008 Share July 15, 2008 ever kena accident before? ram fr back? or u drive hit kerb? Link to post Share on other sites More sharing options...
Darkblue 1st Gear July 15, 2008 Author Share July 15, 2008 No for all of the above How come ? Link to post Share on other sites More sharing options...
Apollo 1st Gear July 15, 2008 Share July 15, 2008 i ever kena accident before lor.. then the fixing pin for the steering pinion dislodge fr firewall. steering go saynak... Link to post Share on other sites More sharing options...
Darkblue 1st Gear July 15, 2008 Author Share July 15, 2008 But really sian... I really pek chek with the road conditions esp building new MRT areas, you know those roads with metal plates ? Due to the high uneven-ness when I see cars including mine go pass, will have "CLUNK !" sound, I am thinking everyday I drive pass sure alignment & suspension go Link to post Share on other sites More sharing options...
Kawarides Neutral Newbie July 16, 2008 Share July 16, 2008 Thats the way how our "garment" encouraged us to change our ride.Then we would have 1st class public transport & "new" cars on the road with "new" IU model to beep away our money to them at a faster rate ↡ Advertisement Link to post Share on other sites More sharing options...
Wheel bolts and Wheel spacer
Wheel Spacer Installation DIY
Wheel Spacer, where to buy?
Steering leather wrapping
Wheel Hubs
Wheel Hubs
Porsche’s First Steer-By-Wire System Is Designed For Less Feedback, Not More
