Ben123 Neutral Newbie August 26, 2008 Share August 26, 2008 My car alarm went bonker this morning. Cannot unlock with the gadget and had to manually unlocked using the key. The moment I unlocked, the alarm sounded non-stop. I reached for the reset button below the ignition switch but could not silence the alarm despite pressing several times. Can this be repaired or is it time to change the alarm system? ↡ Advertisement Link to post Share on other sites More sharing options...
Speddevil Neutral Newbie August 26, 2008 Share August 26, 2008 Bro there is a short circuit in the alarm. Just go down to any accessories shop to rectify it. Think must change the whole module - alarm system Link to post Share on other sites More sharing options...
Spidercool 1st Gear August 26, 2008 Share August 26, 2008 did you turn your key to "ON" position in your car, before you pressed and hold-on the reset button ? What car you driving? OEM supplied alarm ? or self installed? Brand? Link to post Share on other sites More sharing options...
Paikia_rav Neutral Newbie August 26, 2008 Share August 26, 2008 Cheap alarms ain't Good. Good alarms ain't Cheap. Link to post Share on other sites More sharing options...
Speed_ong Clutched August 26, 2008 Share August 26, 2008 You can take a look here. http://www.sgstream.org/forum//showthread.php?t=7606 Link to post Share on other sites More sharing options...
Speddevil Neutral Newbie August 26, 2008 Share August 26, 2008 Bro if got immobiliser can installed? Link to post Share on other sites More sharing options...
Ben123 Neutral Newbie August 26, 2008 Author Share August 26, 2008 Didn't know I need to turn to "ON" before pressing the button. I will try again. Mine is OEM supplied and I am driving a 3 yr old Lancer. Link to post Share on other sites More sharing options...
Speddevil Neutral Newbie August 26, 2008 Share August 26, 2008 That's for resetting the alarm system Link to post Share on other sites More sharing options...
Redplanet Clutched August 27, 2008 Share August 27, 2008 Could be a simple case of weak or flat battery in your remote. If you had armed it using the remote, unlocking the car manually by using key will cause the alarm to go off... Doesn't seem that your alarm is going bonkers, its just doing what it's programmed to do... Link to post Share on other sites More sharing options...
Calefare Neutral Newbie August 27, 2008 Share August 27, 2008 Need to do bypass I think... Link to post Share on other sites More sharing options...
Spidercool 1st Gear August 27, 2008 Share August 27, 2008 Hahaha....when you are panic and not prepared, you'll get into a mess. Try resetting the alarm. See attach for the nissan OEM stock alarm manual. Hope able to help if it works. ↡ Advertisement Link to post Share on other sites More sharing options...
Aftermarket Alarm
Aftermarket Alarm
Aftermarket car alarm
Car Alarm
Car Alarm
Car alarm issue
Car alarm issue
Alarm issue
Alarm issue
Alarm and Lock issue
Any bro using SPY 2 way Alarm
Viper Alarm - Where to get?
