Civic155 Neutral Newbie October 6, 2008 Share October 6, 2008 Hi all, Any place to recommend for timing belt change and how much? ↡ Advertisement Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear October 13, 2008 Share October 13, 2008 Bro, if you wanna save some $$$, maybe can get the parts from stockist & then let the workshop do the rest for you Since you are changing the timing belt, might also change the alternate belt, water pump & bearings at the same time as these items are normally changed at this interval Should set you back about 100 plus for the labour i think Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 13, 2008 Share October 13, 2008 I agree with Mzrmazda. Labour is always the main cost for timing belt package change. I always take this as the rough guideline when changing: http://www.leesheng.com.sg/generalrepair.htm Cost abt 240 bucks basic timing belt package with change oil seals, bearings. This exclude the water pump which adds abt another 80 bucks or so. Link to post Share on other sites More sharing options...
Civic155 Neutral Newbie October 13, 2008 Author Share October 13, 2008 Thanks a lot Link to post Share on other sites More sharing options...
Modykoh 1st Gear October 13, 2008 Share October 13, 2008 for those parts, it is better to get the original from stockist. u may want to try meng ghee..they deal with mit part. Link to post Share on other sites More sharing options...
Ah_tee 2nd Gear October 13, 2008 Share October 13, 2008 if its below 500 its cheap ! i heard from some bro CNC package for 80k change is 1.2k ++ with the belt changes Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear October 14, 2008 Share October 14, 2008 Thank you Bro Link to post Share on other sites More sharing options...
Defelio Neutral Newbie October 15, 2008 Share October 15, 2008 Peck Tiong service at Yishun Industrial Park. call Mr ANG. 67550688 / 97243905. I change my belts at 90k with him for about high $100 to low $200. Call him to confirm. Link to post Share on other sites More sharing options...
Jb15 1st Gear November 1, 2008 Share November 1, 2008 Yup for reference and comparison, http://www.mitsubishicars.com.sg/servicemenu/index.html Link to post Share on other sites More sharing options...
Coder Clutched August 15, 2010 Share August 15, 2010 share with all bro. I got original timing belt at yew tee AND bearing for $55 + $26. friend in m'sia bring me to a JB workshop, charge RM60 labour. total is $100 a bit. Lancer engine is same as Waja engine, they very good in that. Link to post Share on other sites More sharing options...
Xing78 Neutral Newbie October 17, 2010 Share October 17, 2010 (edited) Sorry to borrow your thread. I just changed the timing belt at 90K (ride is CS3) and encounters loud "whirling" sound when flooring the accelerator pedal @ neutral gear. Mechanics say it is due to faults on the wheel bearing (new one) so changed to a 2nd new one and also tighten the timing belt but still same "whirling" sound (not so loud this time). The parts are changed using original Waja timing belt and wheel bearing in a Johor Workshop. Anyone here knows which place in Singapore I can purchase the original bearing used by CS3 as I will like to bring this into the Workshop to get it replaced. Thanks Edited October 17, 2010 by Xing78 Link to post Share on other sites More sharing options...
Forte3737 5th Gear October 17, 2010 Share October 17, 2010 Sorry to borrow your thread. I just changed the timing belt at 90K (ride is CS3) and encounters loud "whirling" sound when flooring the accelerator pedal @ neutral gear. Mechanics say it is due to faults on the wheel bearing (new one) so changed to a 2nd new one and also tighten the timing belt but still same "whirling" sound (not so loud this time). The parts are changed using original Waja timing belt and wheel bearing in a Johor Workshop. Anyone here knows which place in Singapore I can purchase the original bearing used by CS3 as I will like to bring this into the Workshop to get it replaced. Thanks min ghee Link to post Share on other sites More sharing options...
Xing78 Neutral Newbie October 17, 2010 Share October 17, 2010 min ghee Do you have any idea on the price of the original wheel bearing (less than SGD30)? The Johor workshop I went used NTN bearing (stock for Waja). Timing belt (RM380+), Bearing(RM50+), coolant change(FOC) + labor (RM60+), RM490. Trying not to overspend as I just forked out RM1850 yesterday (major service + 4 tyres change) Thanks Bro. Link to post Share on other sites More sharing options...
Forte3737 5th Gear October 17, 2010 Share October 17, 2010 Do you have any idea on the price of the original wheel bearing (less than SGD30)? The Johor workshop I went used NTN bearing (stock for Waja). Timing belt (RM380+), Bearing(RM50+), coolant change(FOC) + labor (RM60+), RM490. Trying not to overspend as I just forked out RM1850 yesterday (major service + 4 tyres change) Thanks Bro. give min ghee a call. they will be in a better position to advise you Link to post Share on other sites More sharing options...
Superndyyeo Neutral Newbie January 9, 2013 Share January 9, 2013 Bro, Where can i get CS3 original exhaust on a cheaper price? you can watsapp or sms me @ 96872793 Thanks Link to post Share on other sites More sharing options...
SpeedyJIM Clutched March 28, 2017 Share March 28, 2017 (edited) Hi I recently just bought the whole set Timing belt ( Original ) Water Pump ( Npw ) Timing Bearing ( NTN) wanted to overhaul but end up scarpping. Selling at a lost $120. PM me if interested 97802255 Edited March 28, 2017 by SpeedyJIM Link to post Share on other sites More sharing options...
Vodaboy Neutral Newbie April 13, 2017 Share April 13, 2017 Hi I recently just bought the whole set Timing belt ( Original ) Water Pump ( Npw ) Timing Bearing ( NTN) wanted to overhaul but end up scarpping. Selling at a lost $120. PM me if interested 97802255 I'm interested, but you have any idea of the labour cost involve? Link to post Share on other sites More sharing options...
SpeedyJIM Clutched April 13, 2017 Share April 13, 2017 Should be 100 to 150 ↡ Advertisement Link to post Share on other sites More sharing options...
Rear seat passenger : Do they belt up?
Tool to change Spark Plug
Change Disc Rotors
Change Disc Rotors
X for twitter change request
Lancer ex 1.6 can't accelerate
