Merciwash Neutral Newbie January 10, 2009 Share January 10, 2009 (edited) That can only be silicon stain from wipers plus cheap carwash done under the sun. Clay = useless in this case. Cleaner = will help a bit ( Silicon X is a stronger version ) Window polish = most contain silicon oil rainx = also contain silicon oil all 4 tried and tested if you want to do it yourself only 1 way i know. But any cheap window cleaner wipe the glass everyday until the stin disappear. ( u should see the purple stain slowly fading after a month. don't used your wiper it has a coating of the silicon oil. ) professional will do this compound with rotary than apply rainx. ( 10min ) charges at least $120 than ask you but a new set of wiper. Edited January 10, 2009 by Merciwash ↡ Advertisement Link to post Share on other sites More sharing options...
Merciwash Neutral Newbie January 10, 2009 Share January 10, 2009 That can only be silicon stain from wipers plus cheap carwash done under the sun. Clay = useless in this case. Cleaner = will help a bit Window polish = most contain silicon oil rainx = also contain silicon oil all 4 tried and tested if you want to do it yourself only 1 way i know. But any cheap window cleaner wipe the glass everyday until the stin disappear. ( u should see the purple stain slowly fading after a month. don't used your wiper it has a coating of the silicon oil. ) professional will do this compound with rotary than apply rainx. ( 10min ) charges at least $120 than ask you but a new set of wiper. Link to post Share on other sites More sharing options...
Jerry Clutched January 13, 2009 Author Share January 13, 2009 This is probably an old packaging, but it should not be difficult to look for it This is the other one I used, also effective for my case. Bro, i bought the silicon X aldy.But how do i apply it? Do i apply using the blue sponge and let it dry then buff off? ↡ Advertisement Link to post Share on other sites More sharing options...
Washing machine front loading
Feedback
Feedback
Dealer re-sell problem car
how to remove micro/fine scratches on windscreen
