Beanoyip Turbocharged March 26, 2009 Share March 26, 2009 Guys, I just happened to walk around the car and realised there was some difference between the gap of the rear arches and wheels. Later on i took a measuring tape to measure and indeed both had a difference of about 1-2cm, just wondering if there was any cause for concern? Both front and rear right arches were of the same height except for the rear left which was a bit higher. It's unlikely to be an uneven ground also. Any advise? ↡ Advertisement Link to post Share on other sites More sharing options...
Othello Supersonic March 26, 2009 Share March 26, 2009 (edited) mine was never even to begin with it was even previously ? drive for a few more days and monitor, maybe will adjust back ? you feel different ? or any sound ? leak ? Edited March 26, 2009 by Othello Link to post Share on other sites More sharing options...
Beanoyip Turbocharged March 27, 2009 Author Share March 27, 2009 No ride difference, i only saw a visual difference which is why i checked on it. No sound nothing, yeah will monitor over next few days to confirm. Different tyre pressure wouldn't result in height difference i believe. Link to post Share on other sites More sharing options...
Try_conti 2nd Gear March 27, 2009 Share March 27, 2009 if its tire pressure that resulted in the 2cm diff. then its very noticeable on your tyres aka one will look pretty flat compared to others. I believe yours is not stock suspension ?? Link to post Share on other sites More sharing options...
Beanoyip Turbocharged March 27, 2009 Author Share March 27, 2009 The shock absorbers are stock but springs are not. I wonder is it because the shocks are worn out. Link to post Share on other sites More sharing options...
XLR8 1st Gear March 27, 2009 Share March 27, 2009 The shock absorbers are stock but springs are not. I wonder is it because the shocks are worn out. No wonder bro. Stock shocks and lowered springs will result in this. Cos your absorbers are softer than your springs. Last time my car also like that. Unbalanced height. Link to post Share on other sites More sharing options...
Beanoyip Turbocharged March 27, 2009 Author Share March 27, 2009 So what needs to changed here? Absorbers? I just measured its about 1cm difference in height.. Link to post Share on other sites More sharing options...
XLR8 1st Gear March 27, 2009 Share March 27, 2009 So what needs to changed here? Absorbers? I just measured its about 1cm difference in height.. Ok from my own experience I share. Absorbers need to be harder or at least the same stiffness as your springs. It cannot be the other round cos you will experience 'bottoms up" or ride becomes bouncy or hoppy. You need to get a set of matching absorbers preferbly form the same brand. Btw what is your stiffness of your springs? How many kg front and back? Get coils la, no need to headache. Link to post Share on other sites More sharing options...
Beanoyip Turbocharged March 27, 2009 Author Share March 27, 2009 Brand is ABT, it came with the car so i got no idea how stiff etc it is. I'll go look for Dennis on Monday then. Link to post Share on other sites More sharing options...
Try_conti 2nd Gear March 27, 2009 Share March 27, 2009 coils .... that'll kill the comfort of the spb .... no ? Link to post Share on other sites More sharing options...
Echelon 3rd Gear March 29, 2009 Share March 29, 2009 Rule of thumb for testing suspension is to press the car down with you weight and release, it should not bounce more than once. If more than once, your suspension is kaput. - mechanic at Servo advise me when I notice my rear wheels are closer to the arc than my front wheels, I think either the coils are down but absobers are ok. Anyways I want to change to something stiffer after 110k which is 20k more for me, am already at 90k. Anyways overall driving pattern nowadays is very slow traveling at 80-90km/h on highway, and slow down even more when taking corners. Link to post Share on other sites More sharing options...
Limlien Clutched March 29, 2009 Share March 29, 2009 Coz the tp also very on right.. So better slow down in case. Link to post Share on other sites More sharing options...
XLR8 1st Gear March 30, 2009 Share March 30, 2009 coils .... that'll kill the comfort of the spb .... no ? Can't have best of both worlds la bro Link to post Share on other sites More sharing options...
Try_conti 2nd Gear March 30, 2009 Share March 30, 2009 revert back to stock loh .... Link to post Share on other sites More sharing options...
Fisheye Neutral Newbie March 31, 2009 Share March 31, 2009 (edited) Bro, Changed your timing belt yet??? Any idea when ure going to do it??? 90k leh...I need to change mine as well... Edited March 31, 2009 by Fisheye Link to post Share on other sites More sharing options...
XLR8 1st Gear March 31, 2009 Share March 31, 2009 revert back to stock loh .... Yeee, whole head can go in. Link to post Share on other sites More sharing options...
Echelon 3rd Gear April 1, 2009 Share April 1, 2009 Bro, Changed your timing belt yet??? Any idea when ure going to do it??? 90k leh...I need to change mine as well... You got PM. ↡ Advertisement Link to post Share on other sites More sharing options...
Front lower arm and suspension questions
'Town council rejected compensating me': Driver at loss after Volkswagen damaged by spalling concrete at Tekka Centre carpark
Is your car worth what it cost? [Shocking]
Noise from front engine area (suspension,maybe) when hit bump with left turn
TTC urethane cushion buffer
