Ixat 1st Gear June 7, 2009 Share June 7, 2009 Hi, have been using my GR80 for 50K now. Rotated front to rear every 10K. Wear rate is even between inner and outer of the tire. But the previous front tire which was rotated to the rear looks bald on the surface. But there's 0.6cm thread more before hitting the threadwear indicator in the inner tire as well as the sidewall triangle threadwear marker. Tires grip well in wet and dry. Just a little noiser than before. Its 1yr 8month old now. Should I change based on the thread wear marker or just by eyeballing the surface? Thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Furrynadz 5th Gear June 7, 2009 Share June 7, 2009 as long as the lowest depth hits below 3mm change it Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 7, 2009 Share June 7, 2009 In most countries it is an offence to run on tyres with less than 1.6mm tread depth. Link to post Share on other sites More sharing options...
Jazz 2nd Gear June 8, 2009 Share June 8, 2009 Bottomline, if you feel unsafe, just change it coz it the only contact with the road surface. Link to post Share on other sites More sharing options...
Ixat 1st Gear June 8, 2009 Author Share June 8, 2009 as long as the lowest depth hits below 3mm change it Bro its 3mm starting from the thread wear marker right? Link to post Share on other sites More sharing options...
Ixat 1st Gear June 8, 2009 Author Share June 8, 2009 In most countries it is an offence to run on tyres with less than 1.6mm tread depth. Mines 6mm bro. Link to post Share on other sites More sharing options...
Ixat 1st Gear June 8, 2009 Author Share June 8, 2009 Bottomline, if you feel unsafe, just change it coz it the only contact with the road surface. The grip in dry and wet feels good just like before. Tested on a safe road. Just happen that my friend changed to a new set of GR80 and compared against mine, mine looks bad. My tire mech said another 20K at least before change is required. So tats a little confused. Thanks! Link to post Share on other sites More sharing options...
Furrynadz 5th Gear June 8, 2009 Share June 8, 2009 Bro its 3mm starting from the thread wear marker right? http://www.tirerack.com/videos/video_popup.jsp?video=5 http://www.tirerack.com/tires/tiretech/tec...e.jsp?techid=51 Link to post Share on other sites More sharing options...
Refugee Neutral Newbie June 8, 2009 Share June 8, 2009 Hello bro, if you drive spirited.... corner fast.... then i suggest your change tyre lah. tyres are the only contact points we have to the floor.... I would change my tyre regardless of mileage or age whenever i feel its not up to standard. Besides... tyre so cheap.... MUHAHA!.... generic enough reply anot? Link to post Share on other sites More sharing options...
Ixat 1st Gear June 8, 2009 Author Share June 8, 2009 Hello bro, if you drive spirited.... corner fast.... then i suggest your change tyre lah. tyres are the only contact points we have to the floor.... I would change my tyre regardless of mileage or age whenever i feel its not up to standard. Besides... tyre so cheap.... MUHAHA!.... generic enough reply anot? It just looks not up to standard. But threadwear and grip is sibei standard. Thats why confusing la.....looks matter in this case? Link to post Share on other sites More sharing options...
Refugee Neutral Newbie June 8, 2009 Share June 8, 2009 (edited) In most countries it is an offence to run on tyres with less than 1.6mm tread depth. how to measure 1.6mm? teach me. Edited June 8, 2009 by Refugee Link to post Share on other sites More sharing options...
Godfinger Neutral Newbie June 8, 2009 Share June 8, 2009 (edited) U need a Depth Guage to measure the Tire Thread. Would you want to go to the extend to measure the Thread Depth? What about having uneven tire surface which is caused by Rubber hardening which our naked eyes cant really detect. Heard someone ever mentioned that 40-50K mileage is the average usage for a set of tires. Anything more is For me, I will change tires every 1 1/2 yrs or 40K of usage which ever comes first. Unless I change car in the middle of the tire usage, else I will stick to this protocol. Really like the feeling and shiokness of having new set of tires everytime I changed. Edited June 8, 2009 by Godfinger Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 8, 2009 Share June 8, 2009 You need a depth gauge preferably a digital one. Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 8, 2009 Share June 8, 2009 On the contrary uneven wears and cupping can be very easily detected by just running yr palm along the surface. Link to post Share on other sites More sharing options...
Jazz 2nd Gear June 8, 2009 Share June 8, 2009 As long the mechanic confident to say 20K to go, just save your money and drive carefully. Link to post Share on other sites More sharing options...
Akula Turbocharged June 9, 2009 Share June 9, 2009 50K mileage, time to change. Link to post Share on other sites More sharing options...
Parkingidiot 1st Gear July 14, 2009 Share July 14, 2009 http://www.tirerack.com/videos/video_popup.jsp?video=5 http://www.tirerack.com/tires/tiretech/tec...e.jsp?techid=51 Good links, thanks! Very informative. ↡ Advertisement Link to post Share on other sites More sharing options...
Do I need to change tire ?
Tire patching types and prices
Spare tire. do u remove or leave in boot?
Continental's New Sustainable Tire Concept Revealed At Munich
Top Quiet Car
Top Quiet Car
Spare Tire - where can I find a replacement?
Valve stem washer?
Valve stem washer?
