Ikan Neutral Newbie June 21, 2009 Share June 21, 2009 Hi Bro / Sis Thanks for yours guide:) How to check wether is HID headlight or Normal Halogen light. Off course, HID should be brighter. But is difficult to check below the sunlight :(. Any method to check? Thanks!!!! ↡ Advertisement Link to post Share on other sites More sharing options...
Furrynadz 5th Gear June 21, 2009 Share June 21, 2009 at night, u can see the colour change between switching on immediately and after a couple seconds Link to post Share on other sites More sharing options...
Ikan Neutral Newbie June 21, 2009 Author Share June 21, 2009 But when I collecting car in the afternoon, is very difficult to check this way. But I will try to throw the light to wall to see like what you mention, see any colour change. Thanks a lot:) Or I should open bonnet to take out a buld to see wether is HID or H4 bulb. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear June 21, 2009 Share June 21, 2009 wat car? Link to post Share on other sites More sharing options...
Ikan Neutral Newbie June 21, 2009 Author Share June 21, 2009 Honda insight Link to post Share on other sites More sharing options...
Shawyz Neutral Newbie June 21, 2009 Share June 21, 2009 hey bro, jus take a look at the bulb from the car headlight area. if the bulb is with a metal rod just below the wall of the bulb glass, then its a HID. if without, then its a normal halogen. thats the physical difference by jus looking at the bulb. cheers Link to post Share on other sites More sharing options...
Limbat 1st Gear June 21, 2009 Share June 21, 2009 Hi Bro / Sis Thanks for yours guide:) How to check wether is HID headlight or Normal Halogen light. Off course, HID should be brighter. But is difficult to check below the sunlight :(. Any method to check? Thanks!!!! Another way is to read your car manual, your car sales man can also provide your with this infomation as well. cheers Link to post Share on other sites More sharing options...
Furrynadz 5th Gear June 21, 2009 Share June 21, 2009 jus check the spec in sg carmart last i remember G spec halogen, L spec HID L spec extra is side mirror indicator, fog lamp, hid Link to post Share on other sites More sharing options...
Ikan Neutral Newbie June 21, 2009 Author Share June 21, 2009 Yes, the G spec no HID. But the PL ask Japan side to install for me. Thats why have to double chk. If dont have, i have to ask for refund:). Then install locally. Link to post Share on other sites More sharing options...
Hamburger Hypersonic June 21, 2009 Share June 21, 2009 once HID is turned on, it will flicker like a flash then lights up gradually. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear June 21, 2009 Share June 21, 2009 as hamburger mentioned and shawyz mentioned, look at the bulb, if it has a metal peice from start to end, and flickers when on, its hid Link to post Share on other sites More sharing options...
Hamburger Hypersonic June 21, 2009 Share June 21, 2009 details in xplaination don cum closer than tis Link to post Share on other sites More sharing options...
Phang79 Neutral Newbie June 21, 2009 Share June 21, 2009 Halogen bulbs comes in yellow. If it's white, then it should be HID Link to post Share on other sites More sharing options...
Passion 5th Gear June 21, 2009 Share June 21, 2009 (edited) As one of the TS mention,install locally is it legal?Since it's not factory fitted.If legal,I also want to change my to HID.Since 1.8 Altis also HID. Edited June 21, 2009 by Passion Link to post Share on other sites More sharing options...
Chickenbackside 1st Gear June 21, 2009 Share June 21, 2009 (edited) Halogen bulbs comes in yellow. If it's white, then it should be HID Not very reliable cos factory HID's are 4300k, which look yellowish in isolation. Best way is to look at the bulb. Left halogen, right HID: Edited June 21, 2009 by Chickenbackside Link to post Share on other sites More sharing options...
Ikan Neutral Newbie June 21, 2009 Author Share June 21, 2009 Thanks everyone, you guy are very helpfull:). My G spec original without HID. But is HID compt. So no illegal to install HID. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear June 21, 2009 Share June 21, 2009 Thanks everyone, you guy are very helpfull:). My G spec original without HID. But is HID compt. So no illegal to install HID. still illegal Link to post Share on other sites More sharing options...
Amortifiedpenguin Clutched June 21, 2009 Share June 21, 2009 still illegal seconded. ↡ Advertisement Link to post Share on other sites More sharing options...
How To Check A New Car ?
Are LED lights subject to brightness checks?
Man who removed bus stop bench to check its dimensions for f
