Keen 1st Gear July 1, 2009 Share July 1, 2009 I just had my car polished but there seem to be uneven colour after that, some lighter tone whereas most of it is intact... is it because of the bad polishing? how to get back the original paint work? ↡ Advertisement Link to post Share on other sites More sharing options...
Maddriver 4th Gear July 1, 2009 Share July 1, 2009 I just had my car polished but there seem to be uneven colour after that, some lighter tone whereas most of it is intact... is it because of the bad polishing? how to get back the original paint work? White residual left by improper polishing..Never go through a final polish after abrasive compound... Get an AIO and see if u can remove them..If you have a ROB or DA..This will definitely do the job Link to post Share on other sites More sharing options...
Galantspeedz Turbocharged July 2, 2009 Share July 2, 2009 White residual left by improper polishing..Never go through a final polish after abrasive compound... Get an AIO and see if u can remove them..If you have a ROB or DA..This will definitely do the job Is it similar to white patches that appear, after about a day later? Link to post Share on other sites More sharing options...
Gearoil 1st Gear July 2, 2009 Share July 2, 2009 I just had my car polished but there seem to be uneven colour after that, some lighter tone whereas most of it is intact... is it because of the bad polishing? how to get back the original paint work? Such services employ FTs to do the job....what quality do you expect? Link to post Share on other sites More sharing options...
Maddriver 4th Gear July 2, 2009 Share July 2, 2009 Is it similar to white patches that appear, after about a day later? Yes..could be also solvent escaping and causes a white haze on top but this can be easily remove by washing.. Link to post Share on other sites More sharing options...
Keen 1st Gear July 2, 2009 Author Share July 2, 2009 ok... I will try 101 to remove it, anyway can 105 be layered? Link to post Share on other sites More sharing options...
Maddriver 4th Gear July 2, 2009 Share July 2, 2009 ok... I will try 101 to remove it, anyway can 105 be layered? Yes bro..#105 can be layered.. Link to post Share on other sites More sharing options...
Keen 1st Gear July 2, 2009 Author Share July 2, 2009 I just 101 and 105 my ride, the patchy parts seem to disappear. not very sure because quite dark just now. anyway let's say I just 101 and 105 my ride, then it started raining, will it affect 105 curing? Link to post Share on other sites More sharing options...
Newage Neutral Newbie July 2, 2009 Share July 2, 2009 don't really effect much, wipe dry apply 1 or 2 coat again... i happened to tried out right after a coat of #105, i rinse the whole car wanna look at the water sheeting. wow guess what its sheet like hell... #105 is a really no joke product to have... Link to post Share on other sites More sharing options...
Maddriver 4th Gear July 3, 2009 Share July 3, 2009 I just 101 and 105 my ride, the patchy parts seem to disappear. not very sure because quite dark just now. anyway let's say I just 101 and 105 my ride, then it started raining, will it affect 105 curing? Yes it will... Link to post Share on other sites More sharing options...
Newage Neutral Newbie July 3, 2009 Share July 3, 2009 Yes it will... bro care to share your point of views... Link to post Share on other sites More sharing options...
Keen 1st Gear July 3, 2009 Author Share July 3, 2009 Yes it will... so if it rains after we apply 105, what should we do to remedy it? Link to post Share on other sites More sharing options...
Maddriver 4th Gear July 4, 2009 Share July 4, 2009 so if it rains after we apply 105, what should we do to remedy it? u can layered it on the following day or next car wash... Link to post Share on other sites More sharing options...
Maddriver 4th Gear July 4, 2009 Share July 4, 2009 bro care to share your point of views... it affect polymers from curing.. Link to post Share on other sites More sharing options...
Keen 1st Gear July 5, 2009 Author Share July 5, 2009 so for the next car wash, do i need to apply 101 again before applying 105? or just wash with shampoo will do? Link to post Share on other sites More sharing options...
Maddriver 4th Gear July 5, 2009 Share July 5, 2009 so for the next car wash, do i need to apply 101 again before applying 105? or just wash with shampoo will do? Bro keen..u can skip #101..use #105 for you next session..It does have some very mild cleaning properties.. Link to post Share on other sites More sharing options...
Maddriver 4th Gear July 6, 2009 Share July 6, 2009 so if it rains after we apply 105, what should we do to remedy it? Bro Keen..I had a conversation with DG ealier and they mention the same thing.. Benny, If it rains right after thr # 105 is applied, it will not have time to completely cure, however, if # 601 is used it should cure even if it rains. If # 601 is not used ,I would suggest re-applying the # 105. Regards, Bill Link to post Share on other sites More sharing options...
Maddriver 4th Gear July 6, 2009 Share July 6, 2009 so if it rains after we apply 105, what should we do to remedy it? Bro Keen..I had a conversation with DG ealier and they mention the same thing.. Benny, If it rains right after thr # 105 is applied, it will not have time to completely cure, however, if # 601 is used it should cure even if it rains. If # 601 is not used ,I would suggest re-applying the # 105. Regards, Bill ↡ Advertisement Link to post Share on other sites More sharing options...
Balancing work and family life
