Radiator Cap pressure
Powerhouse
Hi to All,
Can anyone advise on the difference in using the radiator cap pressure? My Vios's stock radiator cap pressure is 0.8bar. Is there any benefits/problems, if I change to 1 BAR or even 1.3 BAR?
Thanks
Hi to All,
Thanks
Increasing the cap pressure will increase the boiling point of the coolant but too high a pressure might cause the undue stress on the radiator and cause premature rupture.
stress also will be to stock radiator rubber hoses, so if you changing, be sure to change to silicone rad hoses as well... add some color to your engine bay too ;)
I changed my stock from 0.9 to 1.1, bcoz I bought wrongly.
Not a lot, but bcoz my heater hose had a minor leak, the coolant keep leaking away.
I decided to put back to 0.9 and tightened up the hose with a new clamp.
So far it appears ok.
There's no gain to overpressurizing your cooling system.
You only increase the chances of stressing other parts.
Hi to All,
Thanks
there are more disadvantages than benefits really, especially if you entire system is not uprated at the same time. you will be putting more stress on the cooling system (pump, thermostat, hoses). you don't really need high pressure rating unless you are driving a track car that needs better cooling due to the high temp operations.
Hi to All,
Thanks
It is advisable to leave it unchanged. Stock system is still the best.
