Voltage Stabilizer,Is it necessary?
Mustang
Sorry, I don't mean you heat shield the nanoplulser.
First of all, you must heat shield the battery to protect it from the hot engine heat. [:p]
Nanopulser or battery desulphator is a 2nd line of defence, imo.
Nanopulser fills the void left by inadequate charging, stop-go conditions and lead sulphation. It is the 1st line of defence since internally you can't do anything. Heatshielding is the 2nd line of defence as I see it since you can either DIY a nitrile rubber casing or the car comes with a ABS box like Audi and other continentals, unlike Jap or Korean makes.
With or without heatshielding makes no difference as I see it as the convectional heat would engulf the battery in the first place (bonnet temps are extremely hot). If the DIY casing is too thick, you are actually trapping radiant heat longer in the battery itself, since the polypropylene casing can no longer dissipate the heat because of the rubber casing. Not to mention the pockets of hot air in between the walls of loose rubber and casing that trap heat further. Catch 22 situation.
My take : Install nanopulser device and forget the heatshield (unless comes stock) [:)]
That will depend on the brand of the VS you are installing, if you are installing the Pivot then you can save your money as there is no difference. I did really throw away my Pivot after I install another brand of VS. [thumbsup]
me too
i also throwws away my PIVOT after install a guy's DIY VS, it's quite good
please dun waste $$$
Hi bro, you are right
many guys take out their itune VS and test my DIY vs, they all feedback better than itune'
even the pivot also
best is do without all these stuff
Stock is good enough.
Perhaps some additional grounding would be good.
the answer is not necessary...if yes all OEM car shd hav already come with VS
to be frank...is a waste of money for just 1 or 2 days of butt feel
even the pivot also
hi Jack, how to know if the capcitors are still working?
I installed the VS in my vios.. it is all a matter of imagination that it improves this and that... basically it does nothing...recommend to go with grounding only which is better for ICE equipments.
Worthy installation is something like Anti Roll Bars from ultra racing which makes significant difference
Check out the thread in that forum.... if any mobile no. is given or not.. he charges RM 160 for the unit. He is an engineer and makes it by himself.... have sold more than few thousand units past years...
How to order from him?
Guest
