Bornno1 1st Gear November 13, 2009 Share November 13, 2009 Noticed a very high pitched constant sound coming from engine bay. Cant trace where the sound is coming from. Is it the belt tensioner or bearings?? Mileage is 70k havent change belts yet. Anyone experienced before? Ride is 06 Vios ↡ Advertisement Link to post Share on other sites More sharing options...
Zniper 2nd Gear November 13, 2009 Share November 13, 2009 timing belt... try to apply some lubricant to it... Link to post Share on other sites More sharing options...
Chiangauto Clutched November 13, 2009 Share November 13, 2009 Noticed a very high pitched constant sound coming from engine bay. Cant trace where the sound is coming from. Is it the belt tensioner or bearings?? Mileage is 70k havent change belts yet. Anyone experienced before? Ride is 06 Vios I would suggest you change your timing belt at 60k.Maybe you need mechanic to check on it.because belt tensioner also can make noise.and you need good oil treatment for your car.hope it help. Link to post Share on other sites More sharing options...
Amsyl Neutral Newbie November 14, 2009 Share November 14, 2009 If it is the timing, your engine will not be running. Most like, the belts turning your aircon compressor & alternator or a worn bearing is causing the sound. have it retensioned or change or spray some wd40 on the bearing. Link to post Share on other sites More sharing options...
Opel17 6th Gear November 14, 2009 Share November 14, 2009 The likely cause is compressor/alternator belt [V-belt construction] slipping, which is due to worn out. Unlikely to be due to timing belt, which is a toothed belt construction. 2nd hand car dealers usually spray WD40 or oil to "solve the problem", only enhance the slipping and remove the noise. Tensioning the belt further may temporary resolve this noise problem, but may cause belt breakage subsequently. Advisable to change the belt. Link to post Share on other sites More sharing options...
Seaweed 1st Gear November 14, 2009 Share November 14, 2009 open the bonnet...you should be able to rough tell where the sound is coming from mah ?? at least narrow down to a area? Link to post Share on other sites More sharing options...
Bornno1 1st Gear November 20, 2009 Author Share November 20, 2009 i open bonnet and seems to be coming from alternator area, but cant pinpoint. Its very high pitched. My car no timing belt only chain. I suspect is the belt tensioner or the alternator bearings kaput liao. But everything is running fine on my car, volt is ard 14.2 when idling. Air con still cold. The noise only can be heard outside but not in car. Sianz irritating :( Link to post Share on other sites More sharing options...
Byond 1st Gear November 20, 2009 Share November 20, 2009 its the fan belt? how long u never changed? i changed mine at 90k km.... cost less than 80$ for my mazda2... Link to post Share on other sites More sharing options...
Bornno1 1st Gear November 20, 2009 Author Share November 20, 2009 all belts havent change yet. mileage reaching 80k. doesn't sound like slipping noise, sounds more like electrical high pitched sound. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear November 20, 2009 Share November 20, 2009 u already answered your own question last night Link to post Share on other sites More sharing options...
Byond 1st Gear November 21, 2009 Share November 21, 2009 its the belt then... go to a ws to have it changed the fan belt is recommended to change at 80k to 100k km Link to post Share on other sites More sharing options...
Octopus 3rd Gear November 21, 2009 Share November 21, 2009 Noticed a very high pitched constant sound coming from engine bay. Cant trace where the sound is coming from. Is it the belt tensioner or bearings?? Mileage is 70k havent change belts yet. Anyone experienced before? Ride is 06 Vios Temporary measure can use silicon grease or silicon spray or dia-electric grease on your belts inner surface, should quiet the belts. Silicon will condition the rubber component in belts, making it slightly softer. DO NOT use WD40 which will damage belts. ↡ Advertisement Link to post Share on other sites More sharing options...
MOM help FTs look for jobs ?
