Getz 1.6m 3DR Specifications,pls
Longg8
hi there,
whats the specs for the above said car model?
does it comes with 4 disc brakes?
what's the 0-100 timing?
etc..
thanks lots.
cheers~
You can try to source for the rear disc overseas.. They come with 4 wheel disc overseas but sadly Singapore normally comes with basic models..
i see.thanks! cos i saw some getz with rear disc brake while some are drum..
initially tot only 1.6 comes with disc brake.
I used to drive the 1.6M Getz for about 3yrs before i scrapped the car..
It's a zippy car that's very fun to drive..small enough to maneuver through anywhere.
Rear is drum...there are conversions but don't really need to la..car isn't that heavy...get better front brakes...
Power wise, it's 105bhp on paper but you won't get that in reality i guess...0-100 in 9.6s also quite hard to get.
Overall, it was a pretty good car at the price i got it for and it served me well...only complain...3dr!!! so troublesome...and almost not aftermarket parts to change to..
BTW, what's a coolent bypass for throttle body? TB doesn't use coolent...air-con is also not climate control so you can't bypass the thermostat either...so i'm not sure what you're asking about
Coolant bypass you need to pull out the two hoses attached to the bottom of the throttle body.
Then use a small metal tube and join the two hoses together and tightened with hose clamp.
Do this when the engine is cold so no hot coolant spill out.
what do u mean by 9.6sec quite hard to get?
u mean it's actually slower than it seems??
