Alvinlkw Neutral Newbie December 22, 2009 Share December 22, 2009 Dear bros and sis out there... When my car goes over a hump, there is always a squeky noise coming from the front wheels. Is that a suspension or coil problem? Doesn't seem that the back has this problem yet. The noise is getting louder right now if I am driving along uneven road surface or just inside car park ramps where there are those 'hole' type of surface. ↡ Advertisement Link to post Share on other sites More sharing options...
Ken4555 1st Gear December 22, 2009 Share December 22, 2009 (edited) car make model age? btw way wat do you mean spring n coil? did you mean damper? Edited December 22, 2009 by Ken4555 Link to post Share on other sites More sharing options...
Alvinlkw Neutral Newbie December 22, 2009 Author Share December 22, 2009 car make model age? btw way wat do you mean spring n coil? did you mean damper? It's a 06 toyotal Altis. Yah, i should think that the spring and coil means damper. Link to post Share on other sites More sharing options...
Ken4555 1st Gear December 22, 2009 Share December 22, 2009 i no expert... but for vios, the back suspension, the spring is next to the damper sperated... unlike the front... you can check with other bros, but seriously, jack the car, spray lotsa WD-40 or similar... squeaky sound should go away... if your dampers still good condition you can invest in a set of spring cushions... then should hv no more sound unless its from your brakes? (unlikely)... change pad or i've seen sprays for disc rotors to quiet it... haha... i feel like a AA consultant in the mag... ps: dont take my word for it... ask around... this just my thoughts... Link to post Share on other sites More sharing options...
Alvinlkw Neutral Newbie December 22, 2009 Author Share December 22, 2009 thanks bro. I doubt it's the rotor because I have got Borneo Motors to skim the surface in Aug due to another kind of noise. I might think it could be either the damper or suspension. Perhaps I chiong over humps quite often...silly.... Link to post Share on other sites More sharing options...
Torquemonster 1st Gear December 22, 2009 Share December 22, 2009 it could be worn suspension bushes.. Link to post Share on other sites More sharing options...
Babyt 4th Gear December 22, 2009 Share December 22, 2009 last time my first gen altis also got squeaky sound w the suspension de... Link to post Share on other sites More sharing options...
Ken4555 1st Gear December 22, 2009 Share December 22, 2009 put handbrake, open bonnet... use both hands + your body weight and try to pump the suspension or get a frd to do it and you put your ears nearer and listen.... :-) Hanip is a toyota expert... ask him lah... Link to post Share on other sites More sharing options...
Woonyang Clutched December 22, 2009 Share December 22, 2009 change your shocks Link to post Share on other sites More sharing options...
Jeron Neutral Newbie December 31, 2009 Share December 31, 2009 Hi Bro, I am also encountering the same problem. squeaky sound when over humps and loud noise when go over man holes .... suspension problem ??? mine is a lancer CS3 Link to post Share on other sites More sharing options...
Chiangauto Clutched December 31, 2009 Share December 31, 2009 think it can be suspension problem.better send to workshop for checking and adjust.sometimes the nut may not tighten well.Mechanic can help you adjust and also ask them to inject some supergrease as ZX1.make your car smooth. Link to post Share on other sites More sharing options...
Nmnhnlm Clutched December 31, 2009 Share December 31, 2009 Its usually due to suspension itself of the bushings. Try spraying some lubricants and see if the noise goes away. ↡ Advertisement Link to post Share on other sites More sharing options...
Reckless Cyclist
Reckless Cyclist
What is this road at buangkok?
