Mini-itx Clutched June 6, 2010 Share June 6, 2010 i prefer the turbos without the high pitch psss pssss... think its like losing usable power if the whistle is too high/loud... if i turbo my sunny my car cheng sure zeng.... The psss psss is unavoidable due to the BOV. You can duct the air back to intake and it will become alot softer. People just like to vent it out for the osund. I also vent it to atmosphere and hence got the pss pss. But I gotten a very soft BOV. Don't want the noise. ↡ Advertisement Link to post Share on other sites More sharing options...
Ken4555 1st Gear June 6, 2010 Share June 6, 2010 The psss psss is unavoidable due to the BOV. You can duct the air back to intake and it will become alot softer. People just like to vent it out for the osund. I also vent it to atmosphere and hence got the pss pss. But I gotten a very soft BOV. Don't want the noise. Whether you decide to vent/wooosh to atmosphere with a BOV, or quietly back to the turbo compressor with a CBV depends on your injection system. Magazine test results over the years have shown little performance difference between the two, other than an interesting aural sound. The reason for fitting one is to reduce strain on the compressor turbine wheel, the intercooler, hoses and fittings. i read another ad says no whistle sond better... seems no much difference.. Link to post Share on other sites More sharing options...
Mini-itx Clutched June 6, 2010 Share June 6, 2010 Whether you decide to vent/wooosh to atmosphere with a BOV, or quietly back to the turbo compressor with a CBV depends on your injection system. Magazine test results over the years have shown little performance difference between the two, other than an interesting aural sound. The reason for fitting one is to reduce strain on the compressor turbine wheel, the intercooler, hoses and fittings. i read another ad says no whistle sond better... seems no much difference.. Its troublesome for me to duct back to the compressor as I have replace the intake pipe with an aluminium for (for CAI purpose). I would need to drill hole, weld adapter and get extra hoses for those. Since there are no environmental issues nor performance issues with venting to atmosphere, I must as well go the easier route. Link to post Share on other sites More sharing options...
Kanta Neutral Newbie August 3, 2010 Share August 3, 2010 Which brand of crank pulley to change? And which workshop to go? What are the pros and cons? Expert advice pls. Seems that you wish to lighten your engine load, you have few choices. 1. Remove power steering. 2. Remove aircon. 3. Install external water/oil pump. Sounds tedious/expensive? Cheaper alternatives, google some race engine photos and see if you can find aluminium crank pulley installed engines on endurance races. Workshop who recommends these, avoid them. Link to post Share on other sites More sharing options...
Cs3rider Neutral Newbie August 24, 2010 Share August 24, 2010 look for T7075 type Link to post Share on other sites More sharing options...
NAI011 Clutched September 3, 2010 Share September 3, 2010 Which brand of crank pulley to change? And which workshop to go? What are the pros and cons? Expert advice pls. it depend on what ride r u drivin , my old VIOS i install MAX.Velocity light-weight pulley it increase my pick-up n improve my fuel consumption ↡ Advertisement Link to post Share on other sites More sharing options...
5 yr car 1500rpm, funny auto crank sound, other rpm no sound
Lightweight Crank pulley
Fair to charge $214 for Crank Shaft Oil Seal minor leak
Question abt pulley
Question abt pulley
Risks of a lightened crank pulley
Mythelogy Lightened Crank Pulley
Where to custom-make supercharger pulley?
