Yeobh 4th Gear June 20, 2010 Share June 20, 2010 Iridium Spark plugs are getting more and more expensive as iridium is a precious metal. Will you reuse your iridium plugs after going through a thorough ultrasonic cleaning process and re-gap back to original size. ↡ Advertisement Link to post Share on other sites More sharing options...
Yuan 6th Gear June 20, 2010 Share June 20, 2010 Iridium Spark plugs are getting more and more expensive as iridium is a precious metal. Will you reuse your iridium plugs after going through a thorough ultrasonic cleaning process and re-gap back to original size. Would you advise to re-use? Link to post Share on other sites More sharing options...
Mr_b20 6th Gear June 20, 2010 Share June 20, 2010 Iridium Spark plugs are getting more and more expensive as iridium is a precious metal. Will you reuse your iridium plugs after going through a thorough ultrasonic cleaning process and re-gap back to original size. that will depend how much is this service cost vs a new set Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged June 20, 2010 Share June 20, 2010 not too sure whats "ultrasonic cleaning process"... I usually clean my cheapo copper plug with throtter body cleaner and regap once in a while and the copper plug could last me almost entire lifespan of my car... dont see any problem with it... Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 21, 2010 Author Share June 21, 2010 Yes I am all for recycling and reuse. Small shops and home use Ultrasonic Cleaners are getting very cheap and therefore the cost of cleaning should not be more than 20% of the spark plug price. Ultrasonic cleaners are widely use initially by hospitals, follow by Hotels and aerospace industries. In the automotive service industry, I notice specialist shops doing carbs and fuel injectors are the very first to use such cleaners. Link to post Share on other sites More sharing options...
Jackwang Neutral Newbie June 21, 2010 Share June 21, 2010 good things! i like it! Link to post Share on other sites More sharing options...
Weiming 1st Gear June 21, 2010 Share June 21, 2010 Yes I would if the cleaning and re-gapping price is reasonable and process is as fast as changing a new set of spark plugs. Link to post Share on other sites More sharing options...
Mini-itx Clutched June 21, 2010 Share June 21, 2010 its a good thing to do. reduce waste. i do clean and regap my plugs from time to time. Link to post Share on other sites More sharing options...
Kangadrool Supersonic June 21, 2010 Share June 21, 2010 Just use good copper plugs from reputable company. Can use it for 20-30K, then replace new sets. Much better. Link to post Share on other sites More sharing options...
Fastjimmy June 21, 2010 Share June 21, 2010 Set of 8 performance/premium grade spark plugs (BRISK) for S$87, fraction of price for new ones no need to clean and consider whether which better deal, want just PM me. Spares from selling off car (never got to fully use thus). Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 21, 2010 Author Share June 21, 2010 (edited) You got the wrong guy, I am not buying plugs, I just throw this idea for discussion only. The whole idea of going green is to Recycle, Reuse or Reduce to reduce the burden on our enviroment. Edited June 21, 2010 by Yeobh Link to post Share on other sites More sharing options...
Trex101 3rd Gear June 21, 2010 Share June 21, 2010 You got the wrong guy, I am not buying plugs, I just throw this idea for discussion only. The whole idea of going green is to Recycle, Reuse or Reduce to reduce the burden on our enviroment. Recycle is good but in a technical point of view there's no way you can replace the eroded material on the centre and ground electrode, even worst, the sand blasting will "rounded" the ground electrode thus making it even more inefficient. Link to post Share on other sites More sharing options...
Mini-itx Clutched June 21, 2010 Share June 21, 2010 Recycle is good but in a technical point of view there's no way you can replace the eroded material on the centre and ground electrode, even worst, the sand blasting will "rounded" the ground electrode thus making it even more inefficient. Eroded center and ground electrode is not a big problem cause you can just regap it. Of course if its too badly eroded, then it has to be replaced. Link to post Share on other sites More sharing options...
Contax 1st Gear June 21, 2010 Share June 21, 2010 do I need a special tools or where can I get it re-gap ? Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 21, 2010 Author Share June 21, 2010 Definetly no point trying to recond highly wear off centre electrode. No sand is being used, ultrasonic cleaner use washing liquid - simple detergent with distilled water may do the work. Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 21, 2010 Author Share June 21, 2010 You need a feeler gauge that comes with a gapping tool. Link to post Share on other sites More sharing options...
Jasonjst 3rd Gear June 21, 2010 Share June 21, 2010 Hi Any idea dimension of the spark plug gap ? Thanks Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 21, 2010 Author Share June 21, 2010 The gap vary from type of plugs and applications. ↡ Advertisement Link to post Share on other sites More sharing options...
Changing of Spark Plugs
5 cents per plastic bag at supermarkets from mid 2023 (Start 3 July 2023)
Recycling Vending Machines Let You Turn Drink Cans & Plastic Bottles Into FairPrice Coupons
Tool to change Spark Plug
Dow said it was recycling our shoes. We found them at an Indonesian flea market
New Recycling Bin from Ikea : re-use, recycle and save Earth
