Eko6 2nd Gear August 1, 2010 Share August 1, 2010 Anyone using fuel additives? Watch this: http://www.youtube.com/watch?v=Vj_21dikYR8 -2% ↡ Advertisement Link to post Share on other sites More sharing options...
5936 1st Gear August 1, 2010 Share August 1, 2010 Thanks for the video and alert. OMG snake oils, and some of them are very ex.. I bet 2T clan will be heard. Too bad video not on fuel injectors cleaner. I usually pour cleaners. Not sure if any negative effect? I hope not, as these are detergent , solvent. Link to post Share on other sites More sharing options...
Yuan 6th Gear August 1, 2010 Share August 1, 2010 Just stick to good engine oil and the grade of fuel to be used as stated in your car manual. Link to post Share on other sites More sharing options...
Verve 1st Gear August 1, 2010 Share August 1, 2010 tried a lot all dun work except fp60 which really cleaned up the engine. when i stopped no diff cos engine already cleaned. 2 mths later i used and the effect (cleaning) is back again. cheap too, comparatively. do a search on fp60. i am no salesman and have no vested interest. just sharing what has benefitted me. Link to post Share on other sites More sharing options...
Byond 1st Gear August 1, 2010 Share August 1, 2010 just pump V power one full tank, surely will feel the difference... Link to post Share on other sites More sharing options...
5936 1st Gear August 1, 2010 Share August 1, 2010 Short trip at high speed cruising will also clean up engine? I felt that after returning trip from Malacca, engine seemed more responsive, eager to rev. Anyone with same observations? Link to post Share on other sites More sharing options...
Ghostami 2nd Gear August 1, 2010 Share August 1, 2010 Not only that, it will charge up your battery which you normally don't in Sg... High speed clears up your carbon build up due to the heat generated at the constant pace of drive at the speed. Link to post Share on other sites More sharing options...
Bulls_is_back 1st Gear August 1, 2010 Share August 1, 2010 When added at a ratio of say 1:50, it means that there is roughly -2% less fuel entering the combustion chamber as measured by the ECU. Maybe that accounts for the loss in power of the Rover-K engine w/ stock ECU that may not be able to take advantage of the now higher octane fuel. Maybe a VTEC, NEO VVL or VVTL-i type NA engine could. In TC/SC engine that is usually knock limited, the higher octane fuel may allow one to run higher boost or more aggressive tuning map for more power. Link to post Share on other sites More sharing options...
Yuan 6th Gear August 2, 2010 Share August 2, 2010 tried a lot all dun work except fp60 which really cleaned up the engine. when i stopped no diff cos engine already cleaned. 2 mths later i used and the effect (cleaning) is back again. cheap too, comparatively. do a search on fp60. i am no salesman and have no vested interest. just sharing what has benefitted me. Where did you get it? I will google it. Link to post Share on other sites More sharing options...
Kakabobo Clutched August 2, 2010 Share August 2, 2010 for me i use redex. it works for me leh. Link to post Share on other sites More sharing options...
Lowrider 2nd Gear August 2, 2010 Share August 2, 2010 How about Mexxon F2-21? Anyone heard of it? Link to post Share on other sites More sharing options...
ER-3682 Supersonic August 2, 2010 Share August 2, 2010 Use V-power,don't need all this crap. Link to post Share on other sites More sharing options...
5936 1st Gear August 2, 2010 Share August 2, 2010 Redex has been around for long time. I used before on & off. But until now, dun know what is in the red stuff. I suspect it to be either fuel oil, 2T, palm oil. really dunno. It's not listed on package. Link to post Share on other sites More sharing options...
Ghostami 2nd Gear August 2, 2010 Share August 2, 2010 Where did you get it? I will google it. Mustafa has it.. Link to post Share on other sites More sharing options...
5936 1st Gear August 2, 2010 Share August 2, 2010 No effect for me. In my case it is $ burner . Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged August 2, 2010 Share August 2, 2010 Thanks for the video and alert. OMG snake oils, and some of them are very ex.. I bet 2T clan will be heard. Too bad video not on fuel injectors cleaner. I usually pour cleaners. Not sure if any negative effect? I hope not, as these are detergent , solvent. hahha... like the new term.."2T" clan... but seriously, for anyone who wanted to add any additive.. y not try some 2 T instead? Link to post Share on other sites More sharing options...
Yuan 6th Gear August 2, 2010 Share August 2, 2010 Mustafa has it.. Thanks. Let me change my oil and enjoy first. Link to post Share on other sites More sharing options...
Ken4555 1st Gear August 2, 2010 Share August 2, 2010 hahha... like the new term.."2T" clan... but seriously, for anyone who wanted to add any additive.. y not try some 2 T instead? you faster than me 3mins to reply.... arghhhh... haha.. 2T clan... am i a member? ↡ Advertisement Link to post Share on other sites More sharing options...
Where to mod fuel needle?
Fuel Plus Meet Up
Fuel Plus Meet Up
