NAI011 Clutched August 31, 2010 Share August 31, 2010 now using eagle f1 215/45/17, time to change a new set , thought of changin to 225/50/17 tyre ? any shop sellin a reasonable price got a shop around yio chu kang indust selling $120 pcs ↡ Advertisement Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear September 1, 2010 Share September 1, 2010 now using eagle f1 215/45/17, time to change a new set , thought of changin to 225/50/17 tyre ? any shop sellin a reasonable price got a shop around yio chu kang indust selling $120 pcs Can compare prices with tyrepac first? They quote prices in pair Link to post Share on other sites More sharing options...
NAI011 Clutched September 2, 2010 Author Share September 2, 2010 thanks 4 ur info will look into it Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear September 2, 2010 Share September 2, 2010 now using eagle f1 215/45/17, time to change a new set , thought of changin to 225/50/17 tyre ? any shop sellin a reasonable price got a shop around yio chu kang indust selling $120 pcs Safety First: compare tire sizes to check if safe to do so with bigger diameter (may exceeds recommended safety threshold: steering/braking) Link to post Share on other sites More sharing options...
Civic6656 1st Gear September 3, 2010 Share September 3, 2010 Safety First: compare tire sizes to check if safe to do so with bigger diameter (may exceeds recommended safety threshold: steering/braking) Ya boy. Better stick back to the same overall rolling diameter. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear September 3, 2010 Share September 3, 2010 now using eagle f1 215/45/17, time to change a new set , thought of changin to 225/50/17 tyre ? any shop sellin a reasonable price got a shop around yio chu kang indust selling $120 pcs very oversized 215 45 u can go 225 45 or 205 50 Link to post Share on other sites More sharing options...
NAI011 Clutched September 6, 2010 Author Share September 6, 2010 driving civic fd 4 manual , still got space for bigger diameter wheel ask KMH SE , they said it's ok but fuel consumption will increase ... Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear September 6, 2010 Share September 6, 2010 Can compare prices with tyrepac first? They quote prices in pair Apology: overlooked the small prints Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear September 6, 2010 Share September 6, 2010 driving civic fd 4 manual , still got space for bigger diameter wheel ask KMH SE , they said it's ok but fuel consumption will increase ... You may be aware of hypermiling to save on fuel consumption Same diameter tire, slightly narrower tire width/lighter tire (my next tire change less 1kg per tyre) Caution: I drive alone most of the time. If you drive high speed/full load often you, you may stick to stock width tire instead and inflate tire slightly above recommended pressure (those are with air temperature at 20 degrees Celcius) Link to post Share on other sites More sharing options...
Misterg77 Neutral Newbie September 16, 2010 Share September 16, 2010 Remember to check the tire manufactured date. Some people selling cheap tires give you old stock... ↡ Advertisement Link to post Share on other sites More sharing options...
Any recommended tyre shop
Tyre puncture
Tyre puncture
Continental CSC 7.
Continental CSC 7.
