E-Jazz Neutral Newbie September 13, 2010 Share September 13, 2010 Hi bros, Just want to find out whether this is true: My mobile phone holder has a power cable connected to it directly. This cable gets its power from the lighter socket. I have come across reading that when parking overnight, don't leave the power cable in the lighter socket as it will continue to drain battery life of the car. Is this really true? ↡ Advertisement Link to post Share on other sites More sharing options...
Dafansu Turbocharged September 13, 2010 Share September 13, 2010 Hi bros, Just want to find out whether this is true: My mobile phone holder has a power cable connected to it directly. This cable gets its power from the lighter socket. I have come across reading that when parking overnight, don't leave the power cable in the lighter socket as it will continue to drain battery life of the car. Is this really true? once you off your engine it wont works Link to post Share on other sites More sharing options...
E-Jazz Neutral Newbie September 13, 2010 Author Share September 13, 2010 once you off your engine it wont works Meaning to say, once engine is off, power is cut off and leaving the power cable plugged in the socket will not have any effect on the battery of the car? Link to post Share on other sites More sharing options...
Beei 1st Gear September 13, 2010 Share September 13, 2010 Meaning to say, once engine is off, power is cut off and leaving the power cable plugged in the socket will not have any effect on the battery of the car? You are right.. In fact, for newer cars, once you off the engine, most electric equipment have their power cut off, except maybe the high beam and brake light.. Link to post Share on other sites More sharing options...
Tinydog Clutched September 13, 2010 Share September 13, 2010 Not true. All electronics in the market, no matter how advanced it is, will discharge a battery(although it is very slow) even though it is in an off state. This is also known as standby power required by the electronics. Think about this, why is it that if you leave a car untouched for weeks will not be able to start? It all boils down to how good/bad the battery and electronics are. To effective minimize the battery discharging, i would think the best way is to disconnect the battery cables from the car itself. Link to post Share on other sites More sharing options...
SimonTan 2nd Gear September 13, 2010 Share September 13, 2010 People talking about the 12V cirgrette socket having zero current when your switch off your car key. The relay will disconnect the 12V socket in most cars. So the charger plugged in will not charge the phone nor will it drain the battery FROM this socket with the charger plugged in! But your are talking about the alarm, keyless entry, ECU, etc standby power when you switch off the car key. Yes, there will be some drain on the car even when key off for these essential car function. Link to post Share on other sites More sharing options...
SupperTime Clutched September 13, 2010 Share September 13, 2010 Hi bros, Just want to find out whether this is true: My mobile phone holder has a power cable connected to it directly. This cable gets its power from the lighter socket. I have come across reading that when parking overnight, don't leave the power cable in the lighter socket as it will continue to drain battery life of the car. Is this really true? no drain and i have had a transformer in the socket for some time now. Link to post Share on other sites More sharing options...
Ehchang8 Neutral Newbie September 13, 2010 Share September 13, 2010 Not true. All electronics in the market, no matter how advanced it is, will discharge a battery(although it is very slow) even though it is in an off state. This is also known as standby power required by the electronics. Think about this, why is it that if you leave a car untouched for weeks will not be able to start? It all boils down to how good/bad the battery and electronics are. To effective minimize the battery discharging, i would think the best way is to disconnect the battery cables from the car itself. not all electronics lah. it depends on the power switch. if it is a mechanical switch that open up the power line, then it won't drain. if it is solid state type of switch, then yes, it will drain very little power. think it's alright to leave the mobile phone holder plugged. it should not drain any power from battery, even if it does, it's negligible. Link to post Share on other sites More sharing options...
Esppppp 1st Gear September 13, 2010 Share September 13, 2010 Hi bros, Just want to find out whether this is true: My mobile phone holder has a power cable connected to it directly. This cable gets its power from the lighter socket. I have come across reading that when parking overnight, don't leave the power cable in the lighter socket as it will continue to drain battery life of the car. Is this really true? I guess it depends on what car. My previous Focus does continue to supply power, een though engine is off. Link to post Share on other sites More sharing options...
Joseph22 Turbocharged September 13, 2010 Share September 13, 2010 its better to plug out anything from the lighter socket in case of energy leakage. infact, its also advicable to switch off the aircon after you park the car. my father ever kenna before, aircon suddenly work and next day, car battery gone. Link to post Share on other sites More sharing options...
Zniper 2nd Gear September 13, 2010 Share September 13, 2010 yup, off engine dan cut off power to the socket liao... Link to post Share on other sites More sharing options...
Comnao 1st Gear September 13, 2010 Share September 13, 2010 my w124 still has electrical supply. i also got use ciggy charger connected to phone. my e39 doesnt. cut off once i pull the key out Link to post Share on other sites More sharing options...
E-Jazz Neutral Newbie September 13, 2010 Author Share September 13, 2010 its better to plug out anything from the lighter socket in case of energy leakage. infact, its also advicable to switch off the aircon after you park the car. my father ever kenna before, aircon suddenly work and next day, car battery gone. I see. I won't say I am glad to learn about this as it isn't really a good thing that happen, but I would say I appreciate your sharing of personal experiences that your father went through. Thanks. my w124 still has electrical supply. i also got use ciggy charger connected to phone. my e39 doesnt. cut off once i pull the key out I see. My power cord have a green light. For my car, when I start engine, the light does come on, when I off the engine, the light goes off. So I assume it is most likely cut off from power. To the rest who replied this thread: I really appreciate the time/effort you guys take to read through my questions, given that you guys are replying so fast, it makes this community a supportive one in my opinion. So a big thanks to all bros/sis. Personally, the fact that there is metal contact still worries me since there are no switches. Even in HDB flats, when we turn off the switch itself, the current still run within the wirings in the socket. Thus this explains my worries. Overall, thanks for replying me everyone. Appreciate it. Link to post Share on other sites More sharing options...
Yeobh 4th Gear September 13, 2010 Share September 13, 2010 Yes most of the car cigarette socket are wire "hot" that means even with the ignition keep in off position there is electrical current flow. Link to post Share on other sites More sharing options...
E-Jazz Neutral Newbie September 13, 2010 Author Share September 13, 2010 Yes most of the car cigarette socket are wire "hot" that means even with the ignition keep in off position there is electrical current flow. I see, thanks Yeobh. =) Well I do believe most of the bros/sis mentioned that it could be cut off in some cars and some may still have current which are negligible. So at the end of the day, i think its individual decision for this in a way. Thanks =) Link to post Share on other sites More sharing options...
Rustyvinyl Neutral Newbie September 13, 2010 Share September 13, 2010 my AD told me to unplug them when engine is off when i sent iin for servicing . i also doubted this theory.... Link to post Share on other sites More sharing options...
Dafansu Turbocharged September 13, 2010 Share September 13, 2010 (edited) i have 4 devices plugged into the same socket via a multi- adapter, no need to worry. Been doing this for past 6 years for the same car Edited September 13, 2010 by Dafansu Link to post Share on other sites More sharing options...
E-Jazz Neutral Newbie September 13, 2010 Author Share September 13, 2010 my AD told me to unplug them when engine is off when i sent iin for servicing . i also doubted this theory.... I see, perhaps for safety reason. Thanks for sharing =) i have 4 devices plugged into the same socket via a multi- adapter, no need to worry. Been doing this for past 6 years for the same car Hi Dafansu, mind if I know what car you are driving? Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding – Jun 2026
Total asset vs car price affordability
Disputes between neighbours - A True story
Xiaomi EV is Coming
Xiaomi EV is Coming
New car discount/price/promo
