Enforcer533 Neutral Newbie October 5, 2010 Share October 5, 2010 (edited) Hi all Went to a shop and ask for the price of a Open pod intake, the SE recommend me not to put coz my car is a AT car. Any reason why ?. the Se just told me that i will expierence slow Pick up. Thanks Edited October 5, 2010 by Enforcer533 ↡ Advertisement Link to post Share on other sites More sharing options...
Lammy84 Neutral Newbie October 5, 2010 Share October 5, 2010 Open pod affects the low end of all cars, not just AT. Just that tradditional AT are already inefficient in putting down power from engine to wheels as compared to MT, this lack of grunt at low end becomes even more pronounced. Also, for AT boxes without manual override, usually the gearbox auto kicks up at low RPMS unless u WOT, so you are suffering all the lag in the low end without enjoying the extra power in the higher end. Just get a boxed induction like ARC does or high flow filter replacement for the stock airbox, much better response in lower end with extra kick in higher end. Its easy to understand why open pod affects low end, imagine u using the same strength to suck on 2 straws, 1 straw has a bigger diameter then the other, which 1 would enable u to suck the water faster if u use less strength? When u just start to suck in the water, u will suck more water from the smaller straw and as you keep increasing your strength, the bigger straw will overtake the small 1 in terms of volume of water taken in. Replace urself with the engine and the water with air, same theory Link to post Share on other sites More sharing options...
Enforcer533 Neutral Newbie October 5, 2010 Author Share October 5, 2010 Open pod affects the low end of all cars, not just AT. Just that tradditional AT are already inefficient in putting down power from engine to wheels as compared to MT, this lack of grunt at low end becomes even more pronounced. Also, for AT boxes without manual override, usually the gearbox auto kicks up at low RPMS unless u WOT, so you are suffering all the lag in the low end without enjoying the extra power in the higher end. Just get a boxed induction like ARC does or high flow filter replacement for the stock airbox, much better response in lower end with extra kick in higher end. Its easy to understand why open pod affects low end, imagine u using the same strength to suck on 2 straws, 1 straw has a bigger diameter then the other, which 1 would enable u to suck the water faster if u use less strength? When u just start to suck in the water, u will suck more water from the smaller straw and as you keep increasing your strength, the bigger straw will overtake the small 1 in terms of volume of water taken in. Replace urself with the engine and the water with air, same theory Hmm bt my AT box has a manual over write. But is kinda crappy. " Link to post Share on other sites More sharing options...
Minikong 1st Gear October 5, 2010 Share October 5, 2010 Hi all Went to a shop and ask for the price of a Open pod intake, the SE recommend me not to put coz my car is a AT car. Any reason why ?. the Se just told me that i will expierence slow Pick up. Thanks but why u want to do an open pod intake? isnt it like a back side that is open all the while Link to post Share on other sites More sharing options...
Moredhel 2nd Gear October 5, 2010 Share October 5, 2010 but why u want to do an open pod intake? isnt it like a back side that is open all the while It's more like having an enlarged mouth without an enlarged throat and lungs. Pointless. Unless you got straight through from mouth to ass. ^^ Link to post Share on other sites More sharing options...
Minikong 1st Gear October 5, 2010 Share October 5, 2010 It's more like having an enlarged mouth without an enlarged throat and lungs. Pointless. Unless you got straight through from mouth to ass. ^^ haha the reason i use back side is because all the s--t hahahaa Link to post Share on other sites More sharing options...
Enforcer533 Neutral Newbie October 5, 2010 Author Share October 5, 2010 but why u want to do an open pod intake? isnt it like a back side that is open all the while Lol the reason y i wanted it is coz it sounds cool lol. i know is kinda stupid. But when u put an open pod in yr car is it a must to change the exhaust ? Link to post Share on other sites More sharing options...
ER-3682 Supersonic October 5, 2010 Share October 5, 2010 Agreed,after putting K&N drop in & HKS exhausts,my car low end torque is less....fuel comsumption goes up in city driving,but better pulling once the techometer hits 4k rpm. Link to post Share on other sites More sharing options...
Lammy84 Neutral Newbie October 5, 2010 Share October 5, 2010 It's more like having an enlarged mouth without an enlarged throat and lungs. Pointless. Unless you got straight through from mouth to ass. ^^ Some cars when switch to open pod the difference can be quite large. The genesis coupe 3.8L V6 for example. A change to an open pod leads to pretty reputable gains of 15ish BHP But bread and butter car change to open pod really a waste of time :P Link to post Share on other sites More sharing options...
Lammy84 Neutral Newbie October 5, 2010 Share October 5, 2010 Lol the reason y i wanted it is coz it sounds cool lol. i know is kinda stupid. But when u put an open pod in yr car is it a must to change the exhaust ? Changing the air intake often belongs to a group of mods called the IHE. Intake, header and exhaust. It often goes hand in hand together with an ECU reflash. On bread and butter cars like altis, swift etc, the gains can be anywhere from 5-20% or more. Best is dont change 1 by 1, change all 3 together then do a retune. If auto, dont go open pod, get a high flow filter much better. Link to post Share on other sites More sharing options...
Minikong 1st Gear October 5, 2010 Share October 5, 2010 (edited) Changing the air intake often belongs to a group of mods called the IHE. Intake, header and exhaust. It often goes hand in hand together with an ECU reflash. On bread and butter cars like altis, swift etc, the gains can be anywhere from 5-20% or more. Best is dont change 1 by 1, change all 3 together then do a retune. If auto, dont go open pod, get a high flow filter much better. any way is a waste of petrol, mod here and there, waste money and waste petrol Edited October 5, 2010 by Minikong Link to post Share on other sites More sharing options...
Moredhel 2nd Gear October 5, 2010 Share October 5, 2010 Changing the air intake often belongs to a group of mods called the IHE. Intake, header and exhaust. It often goes hand in hand together with an ECU reflash. On bread and butter cars like altis, swift etc, the gains can be anywhere from 5-20% or more. Best is dont change 1 by 1, change all 3 together then do a retune. If auto, dont go open pod, get a high flow filter much better. Agree. But I prefer IHESCT. Intake, header, exhaust, supercharge and tune. But to do this, you gotta have some funds as back up to grease the right palms or periodical take down. NOt to mention the balls to drive around during op hours. Auto as mentioned by any bros here, works best with a high flow filter or stock filter. Can be slightly upgraded by removing the resonator and a short ram intake. Link to post Share on other sites More sharing options...
Dscheng 3rd Gear October 5, 2010 Share October 5, 2010 Why not u try closepod, like K&N Apollo kit, simota or bmc cda? With proper C.A.I, u won't feel sluggish pickup. Link to post Share on other sites More sharing options...
Enforcer533 Neutral Newbie October 5, 2010 Author Share October 5, 2010 Why not u try closepod, like K&N Apollo kit, simota or bmc cda? With proper C.A.I, u won't feel sluggish pickup. Hmm srsly i still cant figure out the diff between open pod and CAI both looks the same to me. but do they work differently? Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear October 5, 2010 Share October 5, 2010 open pod filter is not good for AT cars, pick up will be problem. for AT cars, you need the carbon fiber open pod, see below photo. Link to post Share on other sites More sharing options...
Lammy84 Neutral Newbie October 5, 2010 Share October 5, 2010 CAI is essentially an open pod that situated away from original position to a cooler position in the engine bay, its still an open pod by nature Link to post Share on other sites More sharing options...
Lammy84 Neutral Newbie October 5, 2010 Share October 5, 2010 open pod filter is not good for AT cars, pick up will be problem. for AT cars, you need the carbon fiber open pod, see below photo. The one u have depends on the opening of the thing, if the opening is the same as the diameter of the intake pipe, it wont make a difference at all in the top end, or maybe slightly better if the filter can breathe better than your stock one. Link to post Share on other sites More sharing options...
Enforcer533 Neutral Newbie October 5, 2010 Author Share October 5, 2010 Hmm but if i put the simota Carbon charger. do i need to get a new exhaust ??? Another question is if i put that the stock filter box had to be taken out ? ↡ Advertisement Link to post Share on other sites More sharing options...
All about Electric Cars Part 2
Unusual or Rare Cars - Part 3
Which Car and Brand Will Be The Top Seller In 2026?
Ferrari Luce EV
Ferrari Luce EV
Electric cars
Electric cars
