Ethene 1st Gear October 26, 2010 Share October 26, 2010 how long has this been happening? Shull are u from #mp3cable many years ago ? ↡ Advertisement Link to post Share on other sites More sharing options...
Little_prince Supersonic October 26, 2010 Author Share October 26, 2010 it happen over the last week or so... sianz ah.. weekend have to go SLS liaoz Link to post Share on other sites More sharing options...
Baphomet 3rd Gear October 26, 2010 Share October 26, 2010 think is tio virus.. exactly same thing happened to me before. reformat then ok liao. hope you have backup for your files. Link to post Share on other sites More sharing options...
Toledo 1st Gear October 26, 2010 Share October 26, 2010 i had this prob b4 in my old comp. kept rebooting for no apparent reason. suspected hardware but couldn't pin point the source. changed power supply unit, checked the rams, usb etc etc. even reformatted a few times ! as the frequency of the reboots increased (sometimes reboot initiated within 5 min or less after start up), the whole comp eventually died. couldn't even boot up. no beep sound during start up even (the beep sound usually occurs if there is hardware failure for ram, graphics card etc) what u can try to do as a last resort is to re-install and see how things go. hopefully no more auto reboots. else it may point to impending hardware failure. gd luck ! Link to post Share on other sites More sharing options...
Little_prince Supersonic October 26, 2010 Author Share October 26, 2010 i had this prob b4 in my old comp. kept rebooting for no apparent reason. suspected hardware but couldn't pin point the source. changed power supply unit, checked the rams, usb etc etc. even reformatted a few times ! as the frequency of the reboots increased (sometimes reboot initiated within 5 min or less after start up), the whole comp eventually died. couldn't even boot up. no beep sound during start up even (the beep sound usually occurs if there is hardware failure for ram, graphics card etc) what u can try to do as a last resort is to re-install and see how things go. hopefully no more auto reboots. else it may point to impending hardware failure. gd luck ! wow... sounds exactly like mine... hahaha Link to post Share on other sites More sharing options...
Tiger21 Clutched October 26, 2010 Share October 26, 2010 I got 2 different case. Case 1. Keep hanging and rebooting while using, mostly when playing video or graphic intensive usage. Ended up found 1 capacitor on the Video Card burnt/burst. Case 2. New PC sometime can boot sometime cannot. Changed Power supply helped a while then happened again. Bring back to shop they send the motherboard back for repairs/replacement (Gigabyte). Good luck. I know its frustrating. Link to post Share on other sites More sharing options...
Shull Turbocharged October 26, 2010 Share October 26, 2010 (edited) but core temp seem ok... 35-40deg dun think its over heat... think need to format... haiz for my case, usually the CPU will max load indefinitely, which cause the temperature to shot up to >100deg and then BSOD and restart.. soon, i found out that Windows Live Messenger hanged and overloaded my CPU... Edited October 26, 2010 by Shull Link to post Share on other sites More sharing options...
Shull Turbocharged October 26, 2010 Share October 26, 2010 (edited) Shull are u from #mp3cable many years ago ? haha..ya..you are? Edited October 26, 2010 by Shull Link to post Share on other sites More sharing options...
Zniper 2nd Gear October 26, 2010 Share October 26, 2010 i tried the rams... working ok ... no damage etc dun only try the individual rams on slot 1 (i presume u have at least 2 DIMM slots if not 4 slots)... try individual ram on slot 2 and see wat happen... Link to post Share on other sites More sharing options...
Little_prince Supersonic October 27, 2010 Author Share October 27, 2010 haha... sorry guys.. i'm a computer idiot... i guess i gotta pay to get it fixed any guys at SLS you know who can get it done? Link to post Share on other sites More sharing options...
Bystander50 5th Gear October 27, 2010 Share October 27, 2010 There is another hardware possibility not mentioned. Check the capacitors on the motherboard. It is a round cylinder shaped component. Take a look at the top and bottom and see if it is bloated or leaking. A good capacitor should have a flat surface on both ends. Google capacitor plague. This is a common problem in the late 90s to mid 2000. Recently Dell pcs are the latest to be affected by this capacitor problem. Another video streaming product called Slingbox is also affected by it, you can google for more info. I encountered this capacitor problem, just DIY replace it and the problem will be solved. Link to post Share on other sites More sharing options...
Stevle 5th Gear October 28, 2010 Share October 28, 2010 if the pc keep re-booting w/o warning, likely problem is overheating. Make sure your CPU fan is firmly secured to the CPU holder. If one of the CPU fan holder below give way due to brittleness, the unbalanced force may caused the CPU to overheat. sound just about right. happened to mine b4 and i had no clue for quite a while why it keep on rebooting... until i was so pissed off one day that i decided to do a thorough vacuming. then realized the cpu fan was loose and not properly sitting on the chip. fixed that and had no problem since then.. Link to post Share on other sites More sharing options...
PointyEwe Clutched October 28, 2010 Share October 28, 2010 Did you even get to boot up to Win XP before it auto restart? Easiest way is to boot up from the installation CD and reformat the system drive. Try to learn how to troubleshoot the pc yourself. This will save your the pain of lugging it around sls asking for help as this kind of problem will always come back. ↡ Advertisement Link to post Share on other sites More sharing options...
Is it possible to keep deregistered cars?
Fuse keep melting
Fuse keep melting
Being grateful for what we have…
Why keep ICs of military personnel?
How to keep your car cool
Please keep clear yellow box
NTUC Enterprise to buy Kopitiam in move to keep cooked food
