Little_prince Supersonic October 25, 2010 Author Share October 25, 2010 I am surprised no one pointed out overheating as a source? go download this software called CoreTemp.. and see what is the temp your CPU is running at... normal idling shouldn't exceed 50deg.. done... all 4 core abt 35 deg range... no cpu fan error etc... ↡ Advertisement Link to post Share on other sites More sharing options...
Yuri96 Neutral Newbie October 25, 2010 Share October 25, 2010 u got watch those xxx video? if yes probably is kana Virus if not is Motherboard spoil mine have the motherboard problem too. Or maybe the Graphic card is not up to the app standard Link to post Share on other sites More sharing options...
Shull Turbocharged October 25, 2010 Share October 25, 2010 done... all 4 core abt 35 deg range... no cpu fan error etc... how long has this been happening? Link to post Share on other sites More sharing options...
Soho 4th Gear October 25, 2010 Share October 25, 2010 eh bro.. i think if not wrong ur power supply box gone liao... i oso kenna b4.. use half suddenly just restart... Link to post Share on other sites More sharing options...
Watwheels Supersonic October 25, 2010 Share October 25, 2010 hi bros... any IT expert here? my cpu keep rebooting... no error msg etc... but dunno why it keep rebooting after a while? any idea wat happening? running win xp 4gb ram quad core no over clock nothing... Can be a lot of possibilities. Most likely some hardware fault. I experience one time it's a faulty usb cable that kept rebooting my desktop. I troubleshoot almost all of the hardware narrow down to external dvd drive and I thought up lorry liao, it turns out to be the usb cable faulty. Luckily got spare usb cable lying around and got the problem fixed. Link to post Share on other sites More sharing options...
York Clutched October 25, 2010 Share October 25, 2010 eh bro.. i think if not wrong ur power supply box gone liao... i oso kenna b4.. use half suddenly just restart... I 2nd it....unstable voltage rails coses ur system to re-boot....likely is the PSU kaput liao. Link to post Share on other sites More sharing options...
Xtrocious 1st Gear October 25, 2010 Share October 25, 2010 hi bros... any IT expert here? my cpu keep rebooting... no error msg etc... but dunno why it keep rebooting after a while? any idea wat happening? running win xp 4gb ram quad core no over clock nothing... Sounds like an overheating issue - possibly your CPU fan is not working or clogged up with dust... It also could be your graphics card overheating... Suggest you download speedfan to check the temperature of your system... Faulty power supply can also cause this problem.... Link to post Share on other sites More sharing options...
Happily1986 5th Gear October 25, 2010 Share October 25, 2010 my com has this cooling problem..whenever it overheats, it just gives me BSOD without warning whatsover.. maybe you should consider using third party CPU cooler? Link to post Share on other sites More sharing options...
Tigerwoods Turbocharged October 25, 2010 Share October 25, 2010 I am surprised no one pointed out overheating as a source? go download this software called CoreTemp.. and see what is the temp your CPU is running at... normal idling shouldn't exceed 50deg.. Not due to overheating. My Notebook has this problem. But it only goes to sleep mode. I have this software (free) CPU Thermometer and knew that once the computer reaches 85deg, it will go to sleep mode. Link to post Share on other sites More sharing options...
Fresh Clutched October 25, 2010 Share October 25, 2010 is yours an AMD CPU? did you just update to windows SP2 or 3? there is a known issue for that issue, google it, quite easily fixed. Link to post Share on other sites More sharing options...
Zniper 2nd Gear October 25, 2010 Share October 25, 2010 hi bros... any IT expert here? my cpu keep rebooting... no error msg etc... but dunno why it keep rebooting after a while? any idea wat happening? running win xp 4gb ram quad core no over clock nothing... bro believe it or not, if u hav 2x rams or even more rams... take out and put one by one back only to test it out... ultimately the leftover rams are the one tat is working really fine... if u still dun understand wat i'm toking abt, pm me ur no and i can explain to u step by step... Link to post Share on other sites More sharing options...
Donghai Neutral Newbie October 25, 2010 Share October 25, 2010 with regards to fixing the coms at shop, dont do it. get a fren, pay him a token sum, u buy the replacement part. fren better than outside ppl becoz u nv know what info they will steal out of ur com. all the blue film still small case, maybe u got swiss acct worth millions then just lidat gone liao... Link to post Share on other sites More sharing options...
Shull Turbocharged October 25, 2010 Share October 25, 2010 maybe you should consider using third party CPU cooler? nah.. an 80mm fan costing less than $10 did the job.. Link to post Share on other sites More sharing options...
Little_prince Supersonic October 25, 2010 Author Share October 25, 2010 I 2nd it....unstable voltage rails coses ur system to re-boot....likely is the PSU kaput liao. ok bros... will note... maybe a get a spare psu try try! Link to post Share on other sites More sharing options...
Little_prince Supersonic October 25, 2010 Author Share October 25, 2010 bro believe it or not, if u hav 2x rams or even more rams... take out and put one by one back only to test it out... ultimately the leftover rams are the one tat is working really fine... if u still dun understand wat i'm toking abt, pm me ur no and i can explain to u step by step... i tried the rams... working ok ... no damage etc Link to post Share on other sites More sharing options...
Babyckh 5th Gear October 25, 2010 Share October 25, 2010 if the pc keep re-booting w/o warning, likely problem is overheating. Make sure your CPU fan is firmly secured to the CPU holder. If one of the CPU fan holder below give way due to brittleness, the unbalanced force may caused the CPU to overheat. Link to post Share on other sites More sharing options...
Little_prince Supersonic October 25, 2010 Author Share October 25, 2010 but core temp seem ok... 35-40deg dun think its over heat... think need to format... haiz Link to post Share on other sites More sharing options...
Joseph22 Turbocharged October 26, 2010 Share October 26, 2010 i tried the rams... working ok ... no damage etc if its ram problem. you might have to test it for a few days. ↡ Advertisement Link to post Share on other sites More sharing options...
Is it possible to keep deregistered cars?
Fuse keep melting
Fuse keep melting
Being grateful for what we have…
Why keep ICs of military personnel?
How to keep your car cool
Please keep clear yellow box
NTUC Enterprise to buy Kopitiam in move to keep cooked food
