Eng40765 1st Gear November 9, 2010 Share November 9, 2010 Sent my sister car for servicing, got to top up money for 4 extra spark plugs. How come Jazz got 8 sparks?! Anyone knows the advantage of more cylinder/sparks plugs?! ↡ Advertisement Link to post Share on other sites More sharing options...
Civic6656 1st Gear November 9, 2010 Share November 9, 2010 (edited) Sent my sister car for servicing, got to top up money for 4 extra spark plugs. How come Jazz got 8 sparks?! Anyone knows the advantage of more cylinder/sparks plugs?! iDSI models all 8 sparkies. Formal City also. It is supposed to give better combustion for fuel economy. iVTEC models have only 4 sparkies. Edited November 9, 2010 by Civic6656 Link to post Share on other sites More sharing options...
Civic3106 1st Gear November 9, 2010 Share November 9, 2010 Sent my sister car for servicing, got to top up money for 4 extra spark plugs. How come Jazz got 8 sparks?! Anyone knows the advantage of more cylinder/sparks plugs?! iDSI only lah but no iVtec Link to post Share on other sites More sharing options...
ER-3682 Supersonic November 9, 2010 Share November 9, 2010 I remember some older Mercedes V6 & V8 also got 2 spark plugs per cylinder,help to complete burning less pollution,but latest Mercedes is back to 1 spark plug per cylinder,maybe the engineer think it is not needed after all.! Link to post Share on other sites More sharing options...
marwing 1st Gear November 9, 2010 Share November 9, 2010 your Jazz's engine must be DSI technology. go google for Dual Sequential Ignition (DSI) and you will know why. Link to post Share on other sites More sharing options...
Crazecow Neutral Newbie November 9, 2010 Share November 9, 2010 I remember some older Mercedes V6 & V8 also got 2 spark plugs per cylinder,help to complete burning less pollution,but latest Mercedes is back to 1 spark plug per cylinder,maybe the engineer think it is not needed after all.! I don't think new engines these days need dual spark plugs to get good combustion (even old ones don't need). Tuning is what is needed to get good combustion. Link to post Share on other sites More sharing options...
Kangadrool Supersonic November 9, 2010 Share November 9, 2010 Alfa Romeo also had twin sparks before, but now all single sparkie. Link to post Share on other sites More sharing options...
Krado Clutched November 9, 2010 Share November 9, 2010 Anyone knows the advantage of more cylinder/sparks plugs?! Simple. More = Better. Link to post Share on other sites More sharing options...
Minikong 1st Gear November 9, 2010 Share November 9, 2010 wah v8 in disguise! Link to post Share on other sites More sharing options...
Jl1500k Clutched November 9, 2010 Share November 9, 2010 but need to pay more for the "better" Link to post Share on other sites More sharing options...
Krado Clutched November 9, 2010 Share November 9, 2010 but need to pay more for the "better" Simple. Cheap = not good. Good = not cheap. Link to post Share on other sites More sharing options...
Happily1986 5th Gear November 9, 2010 Share November 9, 2010 it is not about having more. Thats not the logic. The idea of having more than one is to allow for a more even combustion of the air-fuel mixture. Without going into fluid mechanics, the air-fuel mixture swirl alot in the piston. When the spark plug ignites, not all of the entire mixture ignites. When this happens, there is a loss of would be compression and thus power. At low engine rpm, the swirl is lesser and mixing is less pronounced. Hence the spark plug activate one at a time. The first one to come online is the one nearest to the inlet valve. In theory, the bulk of the mixture should be at the region closest to the intake valve. The second valve comes online near the end of the exhaust phase. This will ignite all the unignited air fuel mixture which would otherwise escape and be lost through the exhaust. At high rpms, the swirl is maximum and both spark plugs fire at the same time. Because the intake and exhaust valves open and close so quickly, it doesn't make a difference whether the twins rise to the occasion one at a time. In fact because the opening and closing are so fast, the piston is virtually blurring to become semi open. Thus, both should fire as fast as possible If you think about it, there is a limit to the angular frequency of firing. For an equivalent volume of air-fuel mixture introduced, more efficient extraction of mechanical work i.e. compression would be made out at low revs. At high rpms due to the the time delay of the ignition timing becoming an issue, the efficiency of the work extraction decreases. This to me, explains why people find that iDS-I peter out at high speeds. Link to post Share on other sites More sharing options...
Itsec 2nd Gear November 9, 2010 Share November 9, 2010 http://asia.vtec.net/Series/FitJazz/lseries/ Link to post Share on other sites More sharing options...
Furrynadz 5th Gear November 9, 2010 Share November 9, 2010 too lazy to design EGR use twin spark Link to post Share on other sites More sharing options...
Happily1986 5th Gear November 9, 2010 Share November 9, 2010 what is EGR? Link to post Share on other sites More sharing options...
Friendstar Supercharged November 9, 2010 Share November 9, 2010 http://asia.vtec.net/Series/FitJazz/lseries/ the person who wrote this article is a genius or wat. super zai. Link to post Share on other sites More sharing options...
Itsec 2nd Gear November 9, 2010 Share November 9, 2010 the person who wrote this article is a genius or wat. super zai. yup... he wrote alot of articles for different models of honda... there should be one for ody also.. ↡ Advertisement Link to post Share on other sites More sharing options...
Changing of Spark Plugs
Tool to change Spark Plug
Pre-2014 Honda Jazz / Fit (GD & GE Series)
Spark Car Care
Spark Car Care
Any Ideas for Cafe with Live Jazz/Rock Music
Aftermarket vs. OEM Spark Plug Wires
