Seaweed 1st Gear November 12, 2010 Share November 12, 2010 (edited) if i have a volume flow rate of 4770L/min thru a 3" diameter pipe. how to calculate the velocity in meters per sec for the flow thru the pipe ? Thanks. Edited November 12, 2010 by Seaweed ↡ Advertisement Link to post Share on other sites More sharing options...
Seaweed 1st Gear November 12, 2010 Author Share November 12, 2010 anyone with any idea ?? 17.43m/sec ??? Link to post Share on other sites More sharing options...
Little_prince Supersonic November 12, 2010 Share November 12, 2010 flow rate / cross sectional area of pipe Link to post Share on other sites More sharing options...
Happily1986 5th Gear November 12, 2010 Share November 12, 2010 (edited) Assumptions: 1.) Incompressible flow i.e. volume conservation = mass conservation 2.) One dimensional flow in x - direction 3.) Fully developed flow Volume flow rate = velocity * cross sectional area Volume flow rate = 4770L/min = 0.0795m^3/s Area = pi* (0.0762/2)^2 Thus, velocity = Volume flow rate / cross sectional area = 17.43m/s Edited November 12, 2010 by Happily1986 Link to post Share on other sites More sharing options...
PointyEwe Clutched November 12, 2010 Share November 12, 2010 Gas flow velocitiy is more complicated than just V/A. Are you using Standard or Normal Conditions? The rated temp & pressure at different conditions affects the velocity tremendously. Link to post Share on other sites More sharing options...
Seaweed 1st Gear November 13, 2010 Author Share November 13, 2010 thanks bro...so my calculation is correct... Q=AxV Link to post Share on other sites More sharing options...
Seaweed 1st Gear November 13, 2010 Author Share November 13, 2010 mine is fuild...straight forward type...gas can compress...so more difficult...but then ....do it once...the next time will get it liao.. Link to post Share on other sites More sharing options...
1fast1 Supersonic November 13, 2010 Share November 13, 2010 if i have a volume flow rate of 4770L/min thru a 3" diameter pipe. how to calculate the velocity in meters per sec for the flow thru the pipe ? Thanks. 4770L/min = (4770*1000)cm^3/(60 sec) = (4770*1000/60)/(100^3)m^3/sec = (4.7/60) m^3/sec = 0.0783333333 m/sec Cross-sectional area of pipe = pi*r^2 = (pi*d^2)/4 = .25*pi*(3in)^2 = [.25*pi*(3*2.54/100)^2]m^2 = 0.00456036731m^2 Hence velocity of flow = flow-rate/cross-sectional area = 0.078333/0.00456036731 = 17.18 m/sec. ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
Dealer re-sell problem car
Own up, do you surf pornhub? 🤔
Discussion on Gout problem
