Joseph22 Turbocharged January 18, 2011 Share January 18, 2011 Hi, As above. or anyone know where i can find it?? need it for my NZXT Phantom CAsing. ↡ Advertisement Link to post Share on other sites More sharing options...
Fireball0088 5th Gear January 18, 2011 Share January 18, 2011 Hi, As above. or anyone know where i can find it?? need it for my NZXT Phantom CAsing. SLS or SLT Link to post Share on other sites More sharing options...
Untitled-Resident Neutral Newbie January 18, 2011 Share January 18, 2011 http://www.orientalmotor.com.sg/product/se...amp;seriesno=50 they have 230mm fans.. Link to post Share on other sites More sharing options...
Rainman 1st Gear January 18, 2011 Share January 18, 2011 http://www.orientalmotor.com.sg/product/se...amp;seriesno=50 they have 230mm fans.. Mines takes AC power. Had for my PC too, overkill for general airflow and noisy, has since removed. Link to post Share on other sites More sharing options...
Joseph22 Turbocharged January 18, 2011 Author Share January 18, 2011 SLS or SLT I know SLS confirm dont have. cause shop there liao. havent check SLT though. SLS biggest fan is 200mm... Thanks. Link to post Share on other sites More sharing options...
Joseph22 Turbocharged January 18, 2011 Author Share January 18, 2011 (edited) http://www.orientalmotor.com.sg/product/se...amp;seriesno=50 they have 230mm fans.. thanks. but is it for CPU?? cause it seems to be selling motor. Edited January 18, 2011 by Joseph22 Link to post Share on other sites More sharing options...
Joseph22 Turbocharged January 18, 2011 Author Share January 18, 2011 Mines takes AC power. Had for my PC too, overkill for general airflow and noisy, has since removed. you want to sell to me?? i am doing cross firing with HD 4890 and 4850. need that fan before I cross fire. HD 4850 famous for high heat. Link to post Share on other sites More sharing options...
Fireball0088 5th Gear January 18, 2011 Share January 18, 2011 you want to sell to me?? i am doing cross firing with HD 4890 and 4850. need that fan before I cross fire. HD 4850 famous for high heat. do you really need such a powerful fan? are you running it in air cond room? Link to post Share on other sites More sharing options...
GLZT 6th Gear January 18, 2011 Share January 18, 2011 you want to sell to me?? i am doing cross firing with HD 4890 and 4850. need that fan before I cross fire. HD 4850 famous for high heat. You just helped me discover that can crossfire with 2 different models, I using HD5850, can recommend me what to crossfire with? My psu 500w nia, so dont rec me overkill and ex one. Link to post Share on other sites More sharing options...
Joseph22 Turbocharged January 18, 2011 Author Share January 18, 2011 You just helped me discover that can crossfire with 2 different models, I using HD5850, can recommend me what to crossfire with? My psu 500w nia, so dont rec me overkill and ex one. Ati cross fire from what i understand work like this. HD NNXX as long as NN is the same can liao. XX not impotant. But if when u cross fire, the higher XX will tune down to follow the slower XX. For your HD 5850, think your PSU is 500 likely no recommendation. Sorry i wasnt an expert, all are via google one. Link to post Share on other sites More sharing options...
Joseph22 Turbocharged January 18, 2011 Author Share January 18, 2011 do you really need such a powerful fan? are you running it in air cond room? I am more of buying a insurance, cause hd48xx series graphic card single card alone already can reach 80deg liao so x-fire even worse. I am using full tower so noise not and issue as the tower will absorb the noise too. Furthermore, i have fan controller so i can still adjust fan speed. Link to post Share on other sites More sharing options...
GLZT 6th Gear January 18, 2011 Share January 18, 2011 Ati cross fire from what i understand work like this. HD NNXX as long as NN is the same can liao. XX not impotant. But if when u cross fire, the higher XX will tune down to follow the slower XX. For your HD 5850, think your PSU is 500 likely no recommendation. Sorry i wasnt an expert, all are via google one. Icic. Thanks, looks like I need to find PSU watt calculator liao. Link to post Share on other sites More sharing options...
Rainman 1st Gear January 18, 2011 Share January 18, 2011 you want to sell to me?? i am doing cross firing with HD 4890 and 4850. need that fan before I cross fire. HD 4850 famous for high heat. Haha...not too sure if it helps for crossfire significantly, previously I used it for overclocking and CPU temp is only better by 2deg, but the noise is unbearable. The overall airflow does not help in my gfx temp also (my 230mm is mounted infront of the casing-push) U can find it everywhere in SLS, pi pi nia around 15 bucks with filter and grill. BTW I'm using a GTX260+ Link to post Share on other sites More sharing options...
Joseph22 Turbocharged January 18, 2011 Author Share January 18, 2011 Haha...not too sure if it helps for crossfire significantly, previously I used it for overclocking and CPU temp is only better by 2deg, but the noise is unbearable. The overall airflow does not help in my gfx temp also (my 230mm is mounted infront of the casing-push) U can find it everywhere in SLS, pi pi nia around 15 bucks with filter and grill. BTW I'm using a GTX260+ At the font??? No wonder no help. Mine is at the side, right on top of my cpu and graphic cards Link to post Share on other sites More sharing options...
R_aquarii 1st Gear January 19, 2011 Share January 19, 2011 nice casing. but then i dont think there is 230mm fan available... ↡ Advertisement Link to post Share on other sites More sharing options...
Anyone watches MMA?
Anyone watches MMA?
Green fingers anyone?
What strange jobs have you done?
What could have causes this car to skid so badly?
Anyone try Cathay Pacific before?
New Zealand - anyone?
