Enforcer533 Neutral Newbie February 2, 2011 Share February 2, 2011 Hi guys just bought a openpod filter but there is no piping to it The diameter of the Openpod is 3" Can anyone recommend where to do the piping for the openpod ? And wat is the price like ?? ↡ Advertisement Link to post Share on other sites More sharing options...
C-K 2nd Gear February 2, 2011 Share February 2, 2011 Fong Kim, Racetech, Jeepchee and many other friendly exhaust shops near you. Price --> should be around 100 to 200 depends on how you wanna get it done. A new MAF adapter might as well needed. Link to post Share on other sites More sharing options...
Enforcer533 Neutral Newbie February 2, 2011 Author Share February 2, 2011 Fong Kim, Racetech, Jeepchee and many other friendly exhaust shops near you. Price --> should be around 100 to 200 depends on how you wanna get it done. A new MAF adapter might as well needed. Bro thanks for your info. coz my ride is a forte like quite hard to find parts for the car " Another thing is which is the optimal place to put the Openpod ? Link to post Share on other sites More sharing options...
Ghostlancer Neutral Newbie February 2, 2011 Share February 2, 2011 U can try looking for Jason aka whitesnail performance. Hp: 97975869. Maybe he can help u Link to post Share on other sites More sharing options...
Slightlyfamous Neutral Newbie February 2, 2011 Share February 2, 2011 Garage R Link to post Share on other sites More sharing options...
Melvyn Neutral Newbie February 2, 2011 Share February 2, 2011 +1. Whitesnail's a decent guy who tries his best to ensure a good and clean installation of the airbox, pipes and shielding. Have seen his work a few of my make's rides and pretty good. To TS bro, first and foremost, do bear in mind that mushrooms are not that great for auto rides so before it goes in have to make some prep for low end to drop slightly. For location you'll have to see see inside the bay where is there a good place big enough to house it without soaking too much heat. As for piping best to use back the existing pipes if possible since the layout and framework is already there. Just have to ring whitesnail to properly insulate it. If really wanna customise pipings then FK would be at the top of my list and if that's the route you take then after's all done take a pic of the customized set up post up let us, or at least me, see see can? Link to post Share on other sites More sharing options...
Enforcer533 Neutral Newbie February 3, 2011 Author Share February 3, 2011 +1. Whitesnail's a decent guy who tries his best to ensure a good and clean installation of the airbox, pipes and shielding. Have seen his work a few of my make's rides and pretty good. To TS bro, first and foremost, do bear in mind that mushrooms are not that great for auto rides so before it goes in have to make some prep for low end to drop slightly. For location you'll have to see see inside the bay where is there a good place big enough to house it without soaking too much heat. As for piping best to use back the existing pipes if possible since the layout and framework is already there. Just have to ring whitesnail to properly insulate it. If really wanna customise pipings then FK would be at the top of my list and if that's the route you take then after's all done take a pic of the customized set up post up let us, or at least me, see see can? Hi bro i tried using the existing intake but is very flimsy and i have to use cable tie to secure it. if i do it at whitesnail wats is the damage roughly ? Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged February 3, 2011 Share February 3, 2011 (edited) Hi bro i tried using the existing intake but is very flimsy and i have to use cable tie to secure it. if i do it at whitesnail wats is the damage roughly ? The stock rubber piping will not do. You need stainless steel or aluminium metal piping to get the job done. Whitesnail does not have customised metal piping as far as i remember so you can forget about him. Go to those proper aftermarket performance workshops like Fong Kim or Garage R to do the piping. Edited February 3, 2011 by Beehive3783 Link to post Share on other sites More sharing options...
Hoytusa84 1st Gear February 3, 2011 Share February 3, 2011 Whitesnail kinda overcharged.. Used to drive Getz and hang out with him.. Link to post Share on other sites More sharing options...
C-K 2nd Gear February 3, 2011 Share February 3, 2011 (edited) Bro, I suggest you go FongKim or Racetech. GarageR is just a little overpriced and they might not want to entertain you unless you drive high-end performance cars like GTR, Evo, WRX. Jason (whitesnail) does not do customised aluminum pipings. However, I believe he has an open/closed pod setup for your ride. http://sgkiaclub.proboards.com/index.cgi?b...137&page=42 Edited February 3, 2011 by C-K Link to post Share on other sites More sharing options...
Enforcer533 Neutral Newbie February 3, 2011 Author Share February 3, 2011 hi guys thanks for the tips btw race tech is Racing technology right ?? i also thinking of doing lowering suspension from him. is it possible to get it below 400 bucks ? Link to post Share on other sites More sharing options...
C-K 2nd Gear February 3, 2011 Share February 3, 2011 yep @ paya ubi ind park I think you can get lowering springs for about $400. keep looking out for 2nd hand lowering springs in Kia forum. you might be able to get it under 200. Link to post Share on other sites More sharing options...
Enforcer533 Neutral Newbie February 3, 2011 Author Share February 3, 2011 yep @ paya ubi ind park I think you can get lowering springs for about $400. keep looking out for 2nd hand lowering springs in Kia forum. you might be able to get it under 200. haha Thanks bro i guessing u r driving a kia =) Link to post Share on other sites More sharing options...
Hoytusa84 1st Gear February 3, 2011 Share February 3, 2011 For T/C cars, will installing open pod suffer on low end? And what is the benefits of open pod on T/C cars? Thanks! Link to post Share on other sites More sharing options...
Enforcer533 Neutral Newbie April 19, 2011 Author Share April 19, 2011 Guys just to check does MAN exhaust do Custom intake piping as well ? Link to post Share on other sites More sharing options...
Sp3cialist Neutral Newbie April 23, 2011 Share April 23, 2011 Forte, Malaysia is beaming with so many parts as its now Naza Forte there. Link to post Share on other sites More sharing options...
Nhrisuzu 1st Gear April 23, 2011 Share April 23, 2011 Forte, Malaysia is beaming with so many parts as its now Naza Forte there. even their polis cars are using Forte.. ↡ Advertisement Link to post Share on other sites More sharing options...
Touch 'n Go App
Touch 'n Go App
Wheel Spacer, where to buy?
Where you cut your hair?
Going to Batam. Where to park overnight ?
NBA - Where Amazing Happens
8jul2024 ciq jb vehicle on fire at the immigration checkpoint counter
Where you put the Thirsty Hippo?
