Hongliang Neutral Newbie February 6, 2011 Share February 6, 2011 Hi, any of you guys experienced the problem of the ABS light turning on sometimes after engine start up and then after a few more trip goes off again after the self check during engine start up? I am driving an Avante. It has happened to me afew times and wondering what could be the problems? ABS Sensor dirty? Any bros here experienced the same and had the problem resolved? Care to share your experience? ↡ Advertisement Link to post Share on other sites More sharing options...
Thugstercena Clutched February 6, 2011 Share February 6, 2011 time to change ur brake pads. Link to post Share on other sites More sharing options...
Happie_gal Neutral Newbie February 6, 2011 Share February 6, 2011 Maybe try checking if it could be a faulty fuse? if not better bring the car back to ad to check asap. Link to post Share on other sites More sharing options...
Hongliang Neutral Newbie February 7, 2011 Author Share February 7, 2011 time to change ur brake pads. The brake light stays on even before move off... it's like when you turn on you engine there will be an ABS check but it fails the check... Does that still mean the brake pad is causing the problem? When I last serviced my car the mechanic also told me that there is still quite alot of brake left... Link to post Share on other sites More sharing options...
Hongliang Neutral Newbie February 9, 2011 Author Share February 9, 2011 Ok... got the code scanned just now by the Hyundai Service center in JB... Fella told me that it would be ok once he did a reset on the ECU but after I got back to Singapore the ABS light turned on again... The error message was: "C1209 - Wheel speed sensor RR-RH Open/Short" I think that should mean that the problem is more or less isolated to the rear right wheel sensor right? It could either be the wiring around the sensor has short circuited or is damaged already right? And at most I just have to change the sensor right? Sensor change usually how much ah? Link to post Share on other sites More sharing options...
Klownyan Neutral Newbie February 9, 2011 Share February 9, 2011 Ok... got the code scanned just now by the Hyundai Service center in JB... Fella told me that it would be ok once he did a reset on the ECU but after I got back to Singapore the ABS light turned on again... The error message was: "C1209 - Wheel speed sensor RR-RH Open/Short" I think that should mean that the problem is more or less isolated to the rear right wheel sensor right? It could either be the wiring around the sensor has short circuited or is damaged already right? And at most I just have to change the sensor right? Sensor change usually how much ah? used to drive a subaru..drive a fr 3 yrs ABS light come out.. when to agent n ask whats the problem MI said ecu n censor...to repair cost almost 3k plus....gheezzz so i just drive that car until sold brake no problem only without ABS Link to post Share on other sites More sharing options...
Watwheels Supersonic February 9, 2011 Share February 9, 2011 One of the four sensors at the wheels could be faulty. Link to post Share on other sites More sharing options...
Str2 Neutral Newbie February 17, 2011 Share February 17, 2011 That means the ABS sensor on the rear wheel right side is faulty. Just buy it fm spare parts shop and replace (labour about $20-$30). Same thing happened to my Honda. ↡ Advertisement Link to post Share on other sites More sharing options...
Cyclops Rear Light - Who came up with it first?
How Much Do You Know About ABS?
Quad Light Bulb Size
Recommendations for light kitchen carpentry and sink works
Mazda 5 ABS error
Mazda 5 ABS error
P2096 Check engine light
