Ithunk 1st Gear February 18, 2011 Share February 18, 2011 as above for stick shift transmission ↡ Advertisement Link to post Share on other sites More sharing options...
Octopus 3rd Gear February 18, 2011 Share February 18, 2011 Usually when down-shift. Link to post Share on other sites More sharing options...
Lectrosphere 1st Gear February 18, 2011 Share February 18, 2011 as above for stick shift transmission i used to start off with gear 2... but heard from my friends in the long run dunno what will happen... since den i guai guai follow suit Link to post Share on other sites More sharing options...
Lectrosphere 1st Gear February 18, 2011 Share February 18, 2011 Usually when down-shift. same same! Link to post Share on other sites More sharing options...
Ithunk 1st Gear February 18, 2011 Author Share February 18, 2011 Usually when down-shift. examples? Link to post Share on other sites More sharing options...
Ithunk 1st Gear February 18, 2011 Author Share February 18, 2011 i shift from 5 to 2 or 4 to 2 depending.... Link to post Share on other sites More sharing options...
Ithunk 1st Gear February 18, 2011 Author Share February 18, 2011 i used to start off with gear 2... but heard from my friends in the long run dunno what will happen... since den i guai guai follow suit i dont think anything will happen.....except tt u will burn more fuel? since gear 1 is meant for moving off Link to post Share on other sites More sharing options...
Lectrosphere 1st Gear February 18, 2011 Share February 18, 2011 i shift from 5 to 2 or 4 to 2 depending.... wah 5 to 2 very hiong.. engine brake? Link to post Share on other sites More sharing options...
Ithunk 1st Gear February 18, 2011 Author Share February 18, 2011 wah 5 to 2 very hiong.. engine brake? no definitely not....foot brake then change Link to post Share on other sites More sharing options...
Ithunk 1st Gear February 18, 2011 Author Share February 18, 2011 foot brake till i feel the car bog...then i will change....which is below 750 rpm to 1500 rpm Link to post Share on other sites More sharing options...
Octopus 3rd Gear February 18, 2011 Share February 18, 2011 examples? Example 1: Cruising at 5th gear....someone E-brake, I too...traffic speed up again, drop 3rd gear (skip gear) to catch up. Example 2: Cruising at 5th gear, approaching a bend...tap brake to slow down....apex of bend, drop 3rd gear (skip gear) to accelerate off. Example 3: Cruising at 5th gear, saw traffic light turning red from far....drop neutral and cruise....traffic light turn green again as I almost reach, drop 2nd or 3rd gear (skip gear) to accelerate Link to post Share on other sites More sharing options...
questionedfish Clutched February 18, 2011 Share February 18, 2011 more often 5-3 or 4-2. seldom skip while accelerating Link to post Share on other sites More sharing options...
Octopus 3rd Gear February 18, 2011 Share February 18, 2011 i used to start off with gear 2... but heard from my friends in the long run dunno what will happen... since den i guai guai follow suit Previously got chance to drive company lorry, usually start from 2nd gear. Link to post Share on other sites More sharing options...
Ithunk 1st Gear February 18, 2011 Author Share February 18, 2011 Example 1: Cruising at 5th gear....someone E-brake, I too...traffic speed up again, drop 3rd gear (skip gear) to catch up. Example 2: Cruising at 5th gear, approaching a bend...tap brake to slow down....apex of bend, drop 3rd gear (skip gear) to accelerate off. Example 3: Cruising at 5th gear, saw traffic light turning red from far....drop neutral and cruise....traffic light turn green again as I almost reach, drop 2nd or 3rd gear (skip gear) to accelerate do u take on a corner without dropping gear? Link to post Share on other sites More sharing options...
Octopus 3rd Gear February 18, 2011 Share February 18, 2011 more often 5-3 or 4-2. seldom skip while accelerating Unless cruising at expressway you saw a chio bu went pass and you want to catch up, then drop a gear to get more torque. Or you see a opening at the faster lane and want to squeeze in, then drop a gear would help you pick up to their speed faster. Link to post Share on other sites More sharing options...
Octopus 3rd Gear February 18, 2011 Share February 18, 2011 do u take on a corner without dropping gear? Yes, if no hurry then enter the bend at optimium speed and gear, and light press on the accelerator all the way out of the bend. Usually this way is faster to clear the bend, smoother too. Link to post Share on other sites More sharing options...
Ithunk 1st Gear February 18, 2011 Author Share February 18, 2011 Example 1: Cruising at 5th gear....someone E-brake, I too...traffic speed up again, drop 3rd gear (skip gear) to catch up. Example 2: Cruising at 5th gear, approaching a bend...tap brake to slow down....apex of bend, drop 3rd gear (skip gear) to accelerate off. Example 3: Cruising at 5th gear, saw traffic light turning red from far....drop neutral and cruise....traffic light turn green again as I almost reach, drop 2nd or 3rd gear (skip gear) to accelerate from what i know 5th gear is over drive....so normally its 4th or 3rd when taking on corners....and of course it depends on how much power u want...lol driving manual as a function is easy....but to totally be an expert in manual is a whole different ball game...expert meaning knowing when is the optimal rpm to upshift downshift etc. Link to post Share on other sites More sharing options...
Ithunk 1st Gear February 18, 2011 Author Share February 18, 2011 Yes, if no hurry then enter the bend at optimium speed and gear, and light press on the accelerator all the way out of the bend. Usually this way is faster to clear the bend, smoother too. haha...ok thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Boomers on the road should take mandatory tests
PSA: Driving in Malaysia and How To Handle Accidents and Theft
Any good private driving instructor to recommend?
Where to get Workshop Manual
Class 4 Driving License
Recommendation for private driving instructor near BBDC
