Need help, Headlight not working, but dimmer is ok.
Onghc73
dear Bro & Sis,
Ytd night, after work, on headlight, found very dim, checked & found that only dimmer is working, main headlights are not...
Tried to on high beam also cannot, but flash high beam ok....
Beside go to mechanics for a check later on, any one came across such problem? Need Bro & Sis expertise & knowledge for advises...
Car Make: Yr'05 Altis.
Headlight: Stock 1, not mod..
Battery condition: Just change Aug'10, still in good condition (Checked).
Alternator: just change Aug'10 due to rolling sound..
Thanks in advance.... [:(][:(]
Prolly jus a simple headlight bulb blown. Go to any petrol service center and they prolly will have the right bulb size for u to change.
don't think is simple bulb blown.. '05 altis have separate bulbs for the Hi-Beam and Lo-Beam..
if it is simple bulb blown.. TS will not be able to Flash hi-beam as well instead of just unable to on Hi-Beam.. [:)] [:)]
Thanks for the advices..
when pulling the high beam level, it's work for all headlights (i.e. Main & high beams 1)..
dear Bro & Sis,
updated info,
Is not headlight bulds spoiled, already mentioned that when pulling high beam (i.e. Flashing high beam), all bulbs (including high beam) working.
anyway, change Switch A/S - Headlight, or common name as indicator switch.. all back to normal..
Damages:
Part: $50 + GST
WS Labour: $30
Case Closed.
thanks for all Bro & sis support..
