Athrin 1st Gear March 31, 2011 Share March 31, 2011 Hi all, Im driving a Apr 06 1.8manual civic FD1. I went to do my 70k servicing at Spark Car Care at Braddell on 29mar tuesday. They said there's a minor leak at the bottom of my Crank Shaft Oil Seal & it will cost $214 & about 5-6 hrs to repair/replace. The service advisor say it usually happens when the car reaches around 100k or >100k is is fair or normal to charge $214 for Crank Shaft Oil Seal minor leak to repair/replace? Any cheaper & reliable workshop to repair/replace? tks for all your help ↡ Advertisement Link to post Share on other sites More sharing options...
Luckcent 4th Gear March 31, 2011 Share March 31, 2011 5 - 6 hours to fix oil seal of crank shaft is too long I guess. Go get another quote from other w/s, you will be surprised at the price. Link to post Share on other sites More sharing options...
Byond 1st Gear March 31, 2011 Share March 31, 2011 my fren crank shaft leakage, repaired at 90$ u might wanan check with other ws Link to post Share on other sites More sharing options...
Patangie Neutral Newbie March 31, 2011 Share March 31, 2011 Too expensive. get another quote! Link to post Share on other sites More sharing options...
York Clutched March 31, 2011 Share March 31, 2011 my fren crank shaft leakage, repaired at 90$ u might wanan check with other ws Very much depend on the 'make'.....some car need to strip down many parts before reaching the defected part The fees very much depend on the time spend for the repair. Link to post Share on other sites More sharing options...
Picanto 3rd Gear April 1, 2011 Share April 1, 2011 Hi all, Im driving a Apr 06 1.8manual civic FD1. I went to do my 70k servicing at Spark Car Care at Braddell on 29mar tuesday. They said there's a minor leak at the bottom of my Crank Shaft Oil Seal & it will cost $214 & about 5-6 hrs to repair/replace. The service advisor say it usually happens when the car reaches around 100k or >100k is is fair or normal to charge $214 for Crank Shaft Oil Seal minor leak to repair/replace? Any cheaper & reliable workshop to repair/replace? tks for all your help who are the "THEY"? Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear April 1, 2011 Share April 1, 2011 (edited) Hi all, Im driving a Apr 06 1.8manual civic FD1. I went to do my 70k servicing at Spark Car Care at Braddell on 29mar tuesday. They said there's a minor leak at the bottom of my Crank Shaft Oil Seal & it will cost $214 & about 5-6 hrs to repair/replace. The service advisor say it usually happens when the car reaches around 100k or >100k is is fair or normal to charge $214 for Crank Shaft Oil Seal minor leak to repair/replace? Any cheaper & reliable workshop to repair/replace? tks for all your help Front, rear, or both crank seals? P.S. I'm not sure what the market rate is, but just to make it easier, the front seal is where the belts are connected to, the rear is on the opposite end which will require removal of the gearbox to change it. Edited April 1, 2011 by Elfenstar ↡ Advertisement Link to post Share on other sites More sharing options...
Coolant level going down
NEW AGE POLISH --> Electric Vehicle Sunroof Protection Film
Both BYD and Tesla will now sell you Cat A versions of their popular Seal and Model 3 saloons
The Electric Vehicle Charging Problem
Redmart charges a "Slot Fee" from 15 June
Drive shaft rubber boot/cover
