225/50/17 Odd Size?
Skanps
My car comes with a stock tyre 225/50/17. Considering changing to CSC5 if price is "affordable". However, seems that they only have 215/50/17 or 225/45/17 - No 225/50/17.
Is it safe to fit either 215/50/17 or 225/45/17 in this case? Any trade off?
Thanks!
215/50/17 will give you a -1.52% change in diameter. While 225/45/17 will give you +3.43% increase in diameter. I don't see much problem, but give me a choice between wider and thinner tires, i'll go for wider anytime.
215/50/17 is safer,
next is 245/45/17 or 235/45/17
215 is thinner than his original tires, i dont think it's wise to go for thinner than stock tires. The amount of grip might be compromised. 225 width has at least more contact area, although FC might be slightly affected..
Beg your pardon, but I don't see how a profile 45 tyre can be bigger than a profile 50 tyre, given both have 225 width. In fact the 225/45/17 tyre will have an overall smaller diameter by 3.41 %, out of the recommended range of 3%. Your wheel is smaller, means your ride is also lowered to a small degree.
215/50/17 also not recommended as your stock is 225 width for a reason.
Ur closest fit for same diameter as stock is 245/45/17, but this will increase your FC due to the wider width of the tyres. In that case, since there are no suitable tyre sizes for CSC5, do look out for other brands instead of trying to "force fit" an "affordable" CSC5.
HI all appreciate your prompt reply my current size is 205/65/16 is it ok if i change to 215/55/16 kindly advice if there any problems.
Thanks for all the replies. Think still better to look for the original 225/50/17 which both CSC3 and Michelin PS3 have this size.
Any bros ever compare CSC3 and PS3? Think wet/dry grip should be on par, more interested to know in terms of NOICE and COMFORT.
Cheers!
its NOT ok, it will be way too small, unless your car already lower or u intent to lower your car . u can fit in, drive no problem, but the gap between your car and the body will be very big.
if u change to 215. the aspect ration should 60 ( 215.60.16)
many thanks for your prompt advice .
Cheers!
ps3 wins hands down on wet/dry/noise/handling/comfort
Thanks!
225/50/17 is a very common size and many type of tyre in the market
why should you change your size when a best and OE size is available?
please go hurt for the 225/50/17 , if money not a problem go for quality tyre donr stinge on tyre.
only 4 contacts on the road
Thanks for the assurance! Will probably go ahead with the PS3....unless there is CSC5P is available at this size...
Cheers!
Thanks for the reminder....very true, no matter what, these 4 contacts are our last safety defence on the road. Won't compromise it!
Cheers!
Original 205/65/16
Profile 60 use - 225/60/16 (Safe)
Profile 55 use - 235/55/16 (May rub fender or well when full lock) or 215/55/17 (Safe)
Cheers
Thanks!
CSC5 no stock locally for 225/45R17
Have stock for 215/50R17 and 225/50R17 will reach Singapore in less than a week
Great tyres
Great tyres
Hur? Really? That's good news. Gotta call around to check....
