Lionflyer Neutral Newbie June 11, 2011 Share June 11, 2011 I sent my car in for service and asked them to do a front-rear rotation followed by alignment. But they went and did the alignment and didn't do the rotation. If I do the rotation now separately, will it screw up the alignment since it has been done? ↡ Advertisement Link to post Share on other sites More sharing options...
Unfair 3rd Gear June 11, 2011 Share June 11, 2011 I sent my car in for service and asked them to do a front-rear rotation followed by alignment. But they went and did the alignment and didn't do the rotation. If I do the rotation now separately, will it screw up the alignment since it has been done? No, just go ahead and do your rotation. Do take note if your tyres are directional ones. Link to post Share on other sites More sharing options...
Lionflyer Neutral Newbie June 11, 2011 Author Share June 11, 2011 thanks Bro! that was fast. I called the workshop before collecting my car and it was too late as my mechanic already sent for alignment. (was changing my control arms) have a good weekend! Link to post Share on other sites More sharing options...
Roberttan 5th Gear June 14, 2011 Share June 14, 2011 thanks Bro! that was fast. I called the workshop before collecting my car and it was too late as my mechanic already sent for alignment. (was changing my control arms) have a good weekend! alignment should be last job be carried out . for your case you can try rotate is any problem no choice put it back to original position Link to post Share on other sites More sharing options...
13177 Hypersonic June 14, 2011 Share June 14, 2011 No, just go ahead and do your rotation. Do take note if your tyres are directional ones. What do you mean by directional tyres? Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 14, 2011 Share June 14, 2011 If you mech has the right camber tool, there is no need to send yr ride for alignment work. Just magnetise the camber tool to the wheel brake assembly and check the camber reading. After replacing the lower arm, reset angle with the camber tool. Link to post Share on other sites More sharing options...
Royong Neutral Newbie June 20, 2011 Share June 20, 2011 Hi, U should find out why they did not do a rotation for you. May b they reckon it is not the time yet, so u don't need to rotate. Roy ↡ Advertisement Link to post Share on other sites More sharing options...
Tyre Rotation and balancing
COVID-19: Retrenchments
NUS Grad becomes rubbish collector after retrenchment
My engine after 150,000 kms
Planetary alignment
Planetary alignment
Tyre Rotation every 10k?
